Rear End Ratio?
Old Apr 8, 2012 | 08:36 PM
evan.kelly978's Avatar
evan.kelly978
Rear End Ratio?
I have a new to me 1971 F-100 4x4 with a 360 and what i believe is an np435 mated to a dana21... I dont want to open the axle up to find my rear end ratio. All tags are gona...
Anyone have any idea what my R&P ratio probably is?
Old Apr 8, 2012 | 08:51 PM
Freightrain's Avatar
Freightrain
Jack it up, turn pinion and count tire revolutions. Should be easy to tell what it is.
Old Apr 8, 2012 | 08:57 PM
evan.kelly978
I tried that but which tire do I count from? They turn at different speeds.
Old Apr 9, 2012 | 01:48 AM
RichS2659's Avatar
RichS2659
Actually each tire turns at the same speed because the ratios front and rear have to be almost even, say 4.10 to 4.09, or 3.50 to 3.54. If they didn't, your transfer case would be destroyed from the difference in ratios. Also read the warranty tag on the left door, or the warranty sticker on the door pillar under the striker post for the axle code if they haven't been changed.
Old Apr 9, 2012 | 07:53 AM
Freightrain
Well, better yet, spin the pinion and count the tire revolutions. Doing it the other way usually ends up spinning in opposite directions and will cause irratic readings(due to differential gears). I'm used to spools and tight limited slips which won't have those issues.
Old Apr 9, 2012 | 09:35 AM
evan.kelly978
I jacked the rear end up and turned the driveshaft, the two rear tires turn at different speeds...
Old Apr 9, 2012 | 11:12 AM
Freightrain
If it's an open rear, they will spin on oppposite directions(due to differential) if you spin the tires,. If it does have a limited slip, then it's slipping for some reason(brakes tighter on one side?).
Old Apr 10, 2012 | 04:50 PM
orich's Avatar
orich
The right rear & left front are the drive wheels. lock left front hub turn once, count turns of drive line should do it for your ratio count...The rear will be the ssame ratio.
orich
Corkwheats
Mar 31, 2013 11:27 AM
desbird
Nov 22, 2009 05:56 PM
taylorjgreen
Oct 13, 2008 12:08 AM
z 97ford1
1997 - 2003 F150
Sep 8, 2006 04:14 PM
rhowell
1983 - 2012 Ranger & B-Series
Dec 12, 2005 07:15 PM
