4.0 heater stopped working
Old Dec 30, 2004 | 06:36 PM
i drive a truck's Avatar
i drive a truck
Like the title says my 97 4.0 heater just stopped working. i have checked the thermostat and also the ecu for any codes that it might be putting out. any help on what it could possibly be is appreciated thanks
-IDT
Old Dec 31, 2004 | 12:01 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
Need some more info. For example, it could be a heater core issue - did you check the heater hoses that run to the fire wall (the ones that go to the heater core) to make sure they both are hot? Is the the blower motor (fan) working OK? When you switch modes (floor, defrost, etc.) does the air come out of the proper vent openings? If yes to all of the above, then you probably have a blend door problem. If the blend door is busted, a "workaround" can be found here:
https://www.ford-trucks.com/forums/s...threadid=24962
A blend door repair (replacing the plenum) can be found here:
https://www.ford-trucks.com/forums/s...hreadid=152937
Old Jan 3, 2005 | 07:37 AM
FX4_FAN's Avatar
FX4_FAN
I just ran into this same problem on my 98 4.0 explorer. The heat will work when you first start the truck but if you turn the heat off while your driving the heat will not come back. The fan works and the air comes out the right vents, it's just cool instead of hot. The temp gauge reads normal so I'm not sure.
parker112
Nov 5, 2013 01:53 PM
racingxr
Sep 17, 2009 01:38 PM
RESQD1
1983 - 2012 Ranger & B-Series
Jan 22, 2006 10:35 PM
ericas46
Nov 16, 2004 05:13 PM
Avanti
Aerostar
Mar 19, 2001 08:53 AM
