Water in Fuel - trouble code
Old Dec 30, 2004 | 09:25 AM
tunedportcj5's Avatar
tunedportcj5
How often are you guys draining the water for the fuel pump? I have 6K miles on my '05 F350 and I started getting the "Water in Fuel" message. How come the '05s dont have the drain valve like the earlier 6.0s? You have to unscrew a plug with an allen wrench. What a pain!
Old Dec 30, 2004 | 09:28 AM
brandonconner's Avatar
brandonconner
On my '04 I had to drain 3 times in 15K...complained to the dealer and they said there was a bulletin for the early 04s HFCM. Mine was a couple weeks past the cutoff date but they replaced it anyway, light hasn't come on since and that's been about 6/7k ago
Old Dec 30, 2004 | 09:33 AM
jdadamsjr's Avatar
jdadamsjr
All the 6-ohs have the STUPID allen wrench release !!!
You have to be UNDER the truck to drain it in your face -
stupidest design I've ever seen !!!!
(Can u tell I am not in love with their design )
The first time mine came on - I did drain it... found that sediment DID cause a problem with the original units and they did replace it under warranty...
They recomend draining monthly too - which I don't ...
I TRUST that the water in fuel light will tell me when I need to...
Which I do now that I have about 20K miles since the last time I did it...
Old Dec 30, 2004 | 09:42 AM
Frobozz's Avatar
Frobozz
Supposedly the mid-production '05 changes include a completely new HFCM with a lever operated drain with what looks like a little spigot to attach a hose to. WHAT A CONCEPT!! I'll be buying one of those to retrofit to my early '03, once they're available from the parts counter.
Duncan
Old Dec 30, 2004 | 09:44 AM
jdadamsjr's Avatar
jdadamsjr
Do they !!???!!!
Maybe there will be a recall ?!?!?
It's a safety issue, isn't it ?
you could start a fire with the way it is now, right ?!?!!?
Yeah, tht's my story and I'm sticking to it !
Old Dec 30, 2004 | 10:15 AM
Frobozz's Avatar
Frobozz
Nah, with the original brass plug you couldn't get it out even when you wanted to, so there's no chance of a leak and fire!
(Though to be honest, the flash point of diesel is so much higher than gas, a fuel-leak fire is almost unheard of anyway.)
Duncan
abslayer
6.7L Power Stroke Diesel
13
May 15, 2013 09:50 PM
6.0f350newb
Jul 27, 2011 06:43 PM
mybitta1
Jun 9, 2010 07:15 PM
fairhaven
6.4L Power Stroke Diesel
Apr 26, 2009 04:58 PM
MxRacer32
Feb 10, 2005 05:53 PM
