lowering f150 4x2
Old Jan 9, 2003 | 09:13 PM
bodysaffa's Avatar
bodysaffa
lowering f150 4x2
Hi folks,
does anyone know what is involved in lowering a 4x2?
I wonder about the twin I beam and how it will change the camber. Is the spindle one piece with the axle or does it bolt on? (Can I find drop spindles?)
I am not thinking about anything drastic below stock.
Thanks,
Jay in Reno
Old Jan 9, 2003 | 09:56 PM
Last2Know1's Avatar
Last2Know1
lowering f150 4x2
[updated:LAST EDITED ON 09-Jan-03 AT 10:57 PM (EST)]I don't know about that one. I have an 86 f-150 4x2 302 w aod and I just put on a 6 inch lift with 33inch mud tires and i had to take my truck to a speciality shop and get my I beams bent only cost about 200 bucks but lowering i don't know. good luck
Old Jan 9, 2003 | 10:12 PM
Franklin2's Avatar
Franklin2
lowering f150 4x2
Raising or lowering a twin-I-beam gives you the same camber problems, just in opposite directions. I think they make new lowering I beams don't they? But of course they probably are expensive.
Old Jan 10, 2003 | 09:20 PM
toolslingr's Avatar
toolslingr
lowering f150 4x2
lowering you f150 also,same here the i beams and spindles are two differant peices.DJM suspension offers lowering i beams called dream beams.the i beams and spindles on your truck are held in place by ball joints.if you need any more help drop me a line. :-staun
Old Jan 12, 2003 | 10:04 PM
mustange70's Avatar
mustange70
lowering f150 4x2
Heres what you do. You get 2 inch lower springs for the front, shackles and hangers for the rear and the approtiate size shock. Then you get a set of camber bolts from skyjacker (i think thats who makes em) those camber bolts take care of any camber problems i believe. Then install everything and your ready to go. I am in the process of lowering my truck(below) but i don't have the camber bolts so i'm not sure how they work but i know that they are out there.
Cody, Coutts Alberta
82' Flareside: zoom zoom doesn't even begin to describe it, 2/4 Drop, High Compression 66' 289 backed by a toploader 4 speed and a 3.00:1 9 incher, American Racing AR-23 (series 23) wheels, Upgraded interior, Sony Xplod stereo
Old Jan 13, 2003 | 06:53 PM
pancake's Avatar
pancake
lowering f150 4x2
just my opinion grrr...
if you want something low then buy a car instead...trucks are meant to be higher up
Old Jan 13, 2003 | 09:46 PM
bodysaffa's Avatar
bodysaffa
lowering f150 4x2
Thanks Cody,
Two inches will probably do it.
If I could find a car to haul 4x8 plywood I might buy one. Too bad all the old wagons got crushed. Even so they are too small. Sure a high truck looks tough to some, but I don't need the clearance for road use. Mine's an f 150 and if I ever haul 1/2 a ton it is a rare day.
Jay
Old Jan 13, 2003 | 09:59 PM
Keahi73's Avatar
Keahi73
lowering f150 4x2
>Thanks Cody,
>Jay
Ditto to what Jay said. To each his/her own...thats what makes America great. The freedom to choose what works best for us, and to ask questions freely.
Don't think I would like to see my panel lifted HIGH, and as a matter of fact, I DO have a car.
BTW,everyone, thanks for the info and input on this thread, and the one I asked, it has helped answer alot of questions!!!
Renee'
1955 Ford F-100 Panel
Click link then go to 1955 Ford Panel for updates on project
http://briefcase.yahoo.com/macs55F100
1968 Mustang GT Fastback
Old Jan 14, 2003 | 12:21 PM
Franklin2's Avatar
Franklin2
lowering f150 4x2
Old Feb 10, 2010 | 10:48 PM
hobbes's Avatar
hobbes
@toolslinger
Do you know anyone that makes lowering kits like the dream beams from djm? and have you seen any lowering spring kits? I like the look of the 3/5 djm drop but i think a little more would look a bit better any ideas?
Old Feb 12, 2010 | 09:08 PM
Terpfords's Avatar
Terpfords
I just lowered mine with a set of DJM beams. The stock ball joint has some adjustment and mine rides fine. You can get new hangers and shackles for this year for a bolt on drop of 4". I just took my springs to a spring shop and they re-arched them for a 3" drop and then put on shackles for a total of 4". You can get a good price for the beams at thecustomconnectiononline.com . I haven't found a place that makes springs for our year truck. I was considering cutting my spring but each end has a taper, maybe just take a little off each end? good topic!
Old Feb 12, 2010 | 09:41 PM
newrider3's Avatar
newrider3
Why was it necessary to dig up a thread from '03?
Old Feb 12, 2010 | 09:46 PM
hobbes's Avatar
hobbes
because i didnt look at the date and it was on topic of what i wanted to know?
Memphis_Sean
26
Jul 12, 2014 02:07 PM
mookiex2
New Member Introductions
Aug 8, 2013 01:49 PM
Victor L
Oct 14, 2010 04:55 PM
