overdrive button problem
Old Dec 29, 2004 | 06:25 PM
fordgta's Avatar
fordgta
i bought this truck last year 1996 f150 eddie bauer 4x4. The overdrive button on the shifter never worked. Whats a good starting point on fixing this problem? Is there another way to get it to stay out of overdrive other than the button? Would this involve pulling the steering wheel off? Thanks in advance...
Old Dec 30, 2004 | 11:50 AM
GermanGuy's Avatar
GermanGuy
Overdrive Lock-out Button
Hi...
Havn't done it myself, but here are the instructions from the Ford Manual:
1. Remove the switch cover by inserting a thin screwdriver into the recess at the end of the selector lever and unsnapping the cover from the lever.
2. Insert a thin screwdriver into the slot on the switch and remove the switch by pulling switch out of the lever.
Good Luck Dieter
Old Dec 30, 2004 | 10:06 PM
cangim's Avatar
cangim
Does the switch actually not work, or does the light not come on? You should have to remove the steering wheel, but you will probably have to remove the steering column covers to get access to the wiring.
Old Dec 31, 2004 | 08:25 AM
fordgta's Avatar
fordgta
yeah the wires were cut, so i spliced them together but it still doesnt work. no light and no change in the transmission. So i guess ive got to replace the whole arm.
Old Dec 31, 2004 | 05:17 PM
jaspermaggie's Avatar
jaspermaggie
I had something like that on my explorer. My buckup lights and OD did not work turns out the fuse was blone. The OD and backup light was on the same fuse.
Old Jan 1, 2005 | 12:54 PM
dancedad's Avatar
dancedad
check carefully before you throw away the buck$
I have found this in two of my fords now (95 150 xlt, 95 explorer) and it has been the all in one switch connector wiring, (the main block that is attached to turn/wiper arm left side column)
carefully check all connections into this connector at the column, i think you will find a broken wire or loose connection at the connector, don't assume all is well because everything looks good at the connection, wiggle test them thoroughly!!!!!!
they seem to break or develop problems because of al the tilt up/down motion.
probably metal fatigue at the wire to connector.
check the o/d light and switch by pushing button repeatedly while moving column up and down you may find that it turns off and on in certain positions.
sometimes the o/d is switch still working fine but you just can't see the indicator light because of one broken lead up to the light on your switch.
do not replace this switch unless you have to, it is REALLY expensive.
Old Jan 2, 2005 | 11:34 AM
fordgta's Avatar
fordgta
ok....ill definatley get back into it and check everything before replacing
Old Jan 17, 2005 | 05:38 PM
Kansas-Mike's Avatar
Kansas-Mike
If you leave the O/D off and the light is on, is it suppose to go off when you put it in drive?
Old Jan 17, 2005 | 05:45 PM
Franklin2's Avatar
Franklin2
I have only driven one truck that had this on the lever and this is the way it worked.
If the OD indicator said it was on, it was in OD when you got up to a certain speed.
You had to manually turn it off, and it stayed off as long as the key was on. If you stopped and returned and restarted the truck, it automatically re-engaged the OD function, even though you had it manually off before.
Old Jan 17, 2005 | 06:12 PM
Kansas-Mike
I see, I was concerned w/ the light going off [if the O/D is off] when you put it in drive...When its in park the light stays on...[ if its off] but when i put it in gear [drive] the light goes off......
Aldenh
Jan 30, 2017 04:14 PM
deadfish88
Jan 18, 2005 09:48 PM
black460
16
Dec 6, 2004 05:50 PM
HogTied
Aug 9, 2004 10:35 AM
Bart8109
Aug 6, 2004 06:52 PM
