Stubmle-Surge
Old Dec 28, 2004 | 09:24 PM
wickymustang's Avatar
wickymustang
Stubmle-Surge
I have a 95 F150 with the 300 6cyl, and the good old M5OD with 3.55:1 rear end. It is a 2 wd and while running down the road today it started to stumble or surge at around 40 mph, and as long as I stayed at that speed it would continue, however if I gat it some gas this would stop and if I let off it would stop. What's up? It has been a great runner with no problems, its due for an oil change, but the plugs/wires/cap/rotor are all new and checked out.
Old Dec 30, 2004 | 09:51 PM
jwtaylor's Avatar
jwtaylor
Switch pumps if you have dual tanks and see if it continues...possibly clogged fuel filter.
Old Dec 31, 2004 | 09:28 AM
larry derouin's Avatar
larry derouin
Off idle stumble/surge without same symptoms at idle and under acceleration is indicative of an EGR that's cycling more than it should.
Disconnect the EGR valve, plug the vacuum line and drive it under normal conditions. If the stumble/surge goes away, then pull of the EGR, clean it, and re-assemble it to the engine with a block-off plate (tin can cut out to shape of gasket with a 1/8" hole in middle.). This will restrict the EGR and stop the excess flow causing the stumble/surge.
JWTAYLOR
Replacing the Fuel filter is a good idea but isn't a cause of the problem here. Read the symptoms again.
Larry
Old Dec 31, 2004 | 11:15 AM
corpsedub's Avatar
corpsedub
before trying the above methods i would replace both the throttle body gasket and the upper intake manifild gasket as the stokers tend to collaps and allow un mettered air by. i have the same problem. have not changed the upper intake manifold gasket yet but did the throttle body and noticed a slight improvement. i belive both need to be done though.
Old Dec 31, 2004 | 11:36 AM
jwtaylor's Avatar
jwtaylor
I still wouldn't rule the filter out, while not likely its possible....I don't consider 40 mph to be off idle but then I am guessing as to what it could be.
Go to autozone have them pull the codes then post them up, that will get you in the ballpark of the problem and you can go from there.
I wasn't aware collapesd gaskets was a problem on the 4.9, deteriorated maybe but collapsed...interesting...the upper to lower gasket is pretty wide and thick, it would take some age and serious vacuum to collapse that sucker...I'd think.
Old Jan 1, 2005 | 01:59 PM
wickymustang
Absolutely no codes, stored or otherwise. Fuel filter is on the schedule for replacement this week, along with cleaning the IAC and replacing the gasket, and checking over the TB and gasket.
gnoon
May 24, 2016 11:23 PM
acf6
Dec 23, 2015 12:35 AM
Jmoen7
Aug 25, 2015 09:47 PM
NewGuy_99
May 25, 2006 11:11 PM
Ed_B1
1978 - 1996 Big Bronco
13
Nov 10, 2004 10:05 AM
