flywheel goof!
Old Dec 28, 2004 | 07:32 PM
dodgemahal's Avatar
dodgemahal
flywheel goof!
I removed the flywheel on my 82 f150 inline-6 to get it resurfaced and later read
that I should index its position to the crank for installation purposes, however I did not do this. The motor is on the stand so I can't check it out yet but I'd like to know if I made a mistake and what should I do about it. The motor is rebuilt and ready for the flywheel.....I am hoping it only goes on one way!! Any help would be appreciated. Thanks
Old Dec 28, 2004 | 07:45 PM
malync2's Avatar
malync2
No need to index unless the rotating assembly has had a custom balance job. Mark.
Old Dec 28, 2004 | 07:56 PM
1982fordf100's Avatar
1982fordf100
I changed the clutch in my 95 F150 back in January. I didn't mark the flywheel to the crankshaft when I took it off to have it resurfaced. It only went on one way when I put it back together. I haven't had any vibrations from it so it must be on the right way.
Old Dec 28, 2004 | 08:53 PM
fordman300's Avatar
fordman300
nope your good the bolt holes are unevenly spaced so it will only go on one way and the 200 is a zero balanced motor so it real doesnt matter
Old Dec 28, 2004 | 09:28 PM
dodgemahal's Avatar
dodgemahal
Thanks a lot guys.....now I can sleep tonite......I love this Forum!!
300I6VAN85
May 21, 2024 08:34 AM
4x4ford33
18
Jan 24, 2014 10:56 AM
crazy96863
May 1, 2013 09:11 AM
namdorf
Apr 18, 2008 07:23 PM
wxo
Nov 10, 2007 10:33 PM
