Abs Light
Old Dec 29, 2004 | 09:49 AM
barebackjake's Avatar
barebackjake
ok ill try that, thanks guys. im gonna have to wait till this rain lets up my driveway is 6" deep mud right now.....
Old Dec 30, 2004 | 11:05 PM
444dieselrod's Avatar
444dieselrod
Jake, aren't you an electritican???? maybe I am thinking of someone else.
I definelty agree with the bad ground, I had a Chebby step side that did the same thing, just grounded the two tail lamps together, then to the frame, did the same thing, one bright, one dim, confused me all the way through 4 beers, then decided to ground each light seperatly and it fixed it all. these vehicle's are so strange with there wiring.
Diesel Rod
Old Jan 1, 2005 | 11:17 AM
barebackjake
yeah i am dc power frustrates me some days, with out wiring diagrams i just dont want to dive into it and bake the pcm or my brake controller. i found it too, one of the pin connections on my led's was bent causing it. but the abs light still comes on intemittenly. and i drove it for 2 days in DRY weather with no light i thing somethings getting wet that shouldnt be, light started after rain, actuall started after i was going through a stream crossing almost up to my rocker panels
Old Jan 1, 2005 | 11:18 AM
barebackjake
my low voltage is 120AC mostly work on 2KVA-69KVA
Old Jan 1, 2005 | 11:45 AM
444dieselrod
A Utility Copmany employ I presume, with voltages that high.
Highest I ever played with was 480AC at factory I worked at, and at school, we did a little. after two years of school I decided I wanted to work for the railroad go figure. All the loco's are 600VDC, but they wont let me touch them.
I like vehicle wiring, little odd the way some things are done, but its 12 dc, mean to me NO SHOCKY, which is a good thing. glad to see you got it fixed, now for soem pics of it.
Diesel Rod
Old Jan 1, 2005 | 01:56 PM
barebackjake
yeah i will have some pics up maybe today, abs light still comes on intermittenly.
now its hard to shift think its time for clutch master/slave.
Shadowrider123
19
Dec 19, 2014 08:37 AM
abe
Sep 27, 2012 08:50 PM
short1
Oct 9, 2010 09:24 PM
Waff78
1997 - 2003 F150
Dec 31, 2008 01:18 PM
apbtpetey
Electrical Systems/Wiring
Dec 1, 2008 02:18 PM
