Tail light woes
Old Dec 11, 2014 | 05:47 PM
Shadowrider123's Avatar
Shadowrider123
Tail light woes
When I turn the headlights on both filaments in my tail lights come on.
The turn signals will not work when the headlights are on, but will work when the headlights are off.
I checked the harness at the tail lights. Brown is tail lights, yellow is left, green is right.
What should I check next?
Old Dec 11, 2014 | 07:02 PM
ktnissen's Avatar
ktnissen
I would check the grounds.
Old Dec 11, 2014 | 07:27 PM
yellodog's Avatar
yellodog
park lites are grounding thru the ts bulbs. check ground to bed and light body to bed ground.
Old Dec 11, 2014 | 10:09 PM
Shadowrider123
Some progress. BTW: 1964 Flareside.
I removed the front bulbs and cleaned the contacts. They fit in the sockets very loosely, I had to fiddle with them to get them to come on. The fronts now work as parking lights and turn signals. (On a 64, the park lights go out when the head lights are on)
Am I going to have to replace the front buckets?
On the rear Im still getting both filaments lighting when the tail lights are on. Is that a ground problem? The TL brackets screw into a threaded nutsert on the bed, so I think that Im getting a good ground from the housing to the bed. I hooked battery cables to the housing and frame but that didn't do anything.
Old Dec 12, 2014 | 04:54 AM
jowilker's Avatar
jowilker
To keep it simple, power has to get to the bulb filament for it to glow. If both are glowing, both are being powered, either by direct input or bad grounding back flow.
While this can be aggravating as all get out, it is usually pretty simple when you resolve it. I believe I can speak with authority on this, if it weren't simple I couldn't do it. My 66 would be a daylight driver only.
John
Old Dec 12, 2014 | 08:57 AM
sseebart's Avatar
sseebart
Not entirely sure about the park lights in your truck, but in other Fords of this vintage, the socket is replaceable by itself. Typically, the old sockets crack and get loose, as you describe. Something like this would be a replacement:
Amazon.com: Pico 5455pt All Wthr Dbl Cntct Skt - Ford: Automotive Amazon.com: Pico 5455pt All Wthr Dbl Cntct Skt - Ford: Automotive
~Steve
Old Dec 15, 2014 | 11:18 PM
65F-250FATTYLEEN's Avatar
65F-250FATTYLEEN
I just went through a similar situation with my 65 F-250. It turned out to be a ground issue (my bed wasn't properly grounded) I drilled a hole in the light housing and ran it to my bed. Fixed it right up.
Hope it helps!
Old Dec 15, 2014 | 11:26 PM
Shadowrider123
I added a ground wire from the bed to the frame today. The tail lights screw into the bed so I know that I have a good ground from the housing to the bed.
Could a bad ground on the fronts be causing both my rear filaments to light?
I ordered new lights for the front, DC shipped them today.
Old Dec 16, 2014 | 04:27 AM
jowilker's Avatar
jowilker
Don't presume all is clean on those taillight connections, verify.
John
Old Dec 16, 2014 | 07:06 AM
Shadowrider123
Any idea what this is and where it plugs into?
1964 F100 292/AT
Old Dec 17, 2014 | 04:30 AM
jowilker's Avatar
jowilker
I am going to suggest that it is rigged, and very likely for back up lights. I don't think that is 64 factory.
John
Old Dec 17, 2014 | 09:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Backup lamps introduced in 1967 F100/350's. With A/T, are operated by the NSS located on the steering column thru 1977.
With 3 M/T, backup lamp switch located on the bottom of the steering column under the hood. 4 M/T backup lamp switch threads into the shift tower.
Old Dec 17, 2014 | 09:32 AM
Shadowrider123
Since no one recognizes it, I will take it off and see if it is connected to anything in the column.
It looks to me like it belongs there and it fits the column.
I don't have backup lights, but I don't think the flare is the original bed since it is in perfect condition and the truck is a CC.
Old Dec 17, 2014 | 11:09 AM
SuperSabre's Avatar
SuperSabre
I may be mistaken, but didn't Number Dummy just identify that as your neutral safety switch?
Old Dec 17, 2014 | 11:39 AM
banjopicker66's Avatar
banjopicker66
SS, I understood that ND was not identifying that connector as the NSS, but giving out general information about backup lamps. Perhaps I misunderstood?
The NSS uses a different plug connector than what is in the picture.
I believe the owner's truck uses the same turn signal switch as '65 and '66, possibly later.
If so, then that 2-wire plug is for the taillights, according to the electrical diagrams that I have.
John - Banjo -
