running lean
Old Dec 27, 2004 | 08:44 PM
jmurphy_5's Avatar
jmurphy_5
Unhappy running lean
I have 93 f150 4.9 and i get code that said that i was running lean. i replace o2 senson but code came back. what else could cause this problem. also getting poor milage. about 40 mile per tank less than normal.
thank for any help.
Old Dec 27, 2004 | 09:18 PM
95 F150's Avatar
95 F150
It sounds to me like a vacuum leak, inspect all of the vacuum lines and use some starting fluid and spray it around the intake and listen for a change in engine rpms.
Old Dec 27, 2004 | 11:57 PM
Talyn's Avatar
Talyn
PCV Valve
check rotor for signs of electrical wear.
Clean your air filter?
:P
maybe check your throttle positioning sensor. you can do it with an ohm meter and some paper clips.
Old Dec 28, 2004 | 01:28 PM
MemOrex's Avatar
MemOrex
What code was it? 41? It could be vacuum leaks, but those leaks could also introduce those dreaded EGR codes; 32,33,34,35
Old Dec 28, 2004 | 06:00 PM
mike L's Avatar
mike L
whats the code?
Old Dec 29, 2004 | 10:05 AM
fefarms's Avatar
fefarms
Lean codes and bad mileage can be caused by a mis-firing cylinder. Any oxygen not reacted with fuel will come out the tailpipe and be regarded as "extra" oxygen by the oxygen sensor, even though the rest of the cylinders have a perfect stoichiometric mixture.
Low fuel pressure is another common cause of lean codes.
FordMan10
1997 - 2003 F150
Aug 30, 2010 12:22 AM
tvans63
1997 - 2003 F150
May 4, 2010 08:34 PM
03scf250
General Automotive Discussion
Oct 4, 2009 06:58 PM
2003f150xl
1997 - 2003 F150
Feb 3, 2009 10:12 AM
bighibbi
1997 - 2003 F150
Sep 19, 2007 06:31 PM
