With all of the computer controls on engines these days, how do you find vacuum leaks? Basic question, but in the golden days of carbs, I used ether or WD-40 to find the leaks. Today the computer seems to adjust faster than I can pick up on a change. How do you pinpoint a leak? Like an intake manifold leak? Do you disconnect something before spraying around hoses and mating surfaces?
Does the system have to be in open loop for the spray test to work?
Please help out this heavy junk mechanic, thanks in advance.
Reason: Clarify
You can use propane, Throttle body cleaner. The intake is the tricky part. You have to make sure the thing is sealed good or you get bad readings. If the seal around the body or air cleaner is bad you will know real fast.
Joe if your scan tool will let you watch fuel trims in real time while the engine is running that helps a lot too. If you watch them while you spray carb cleaner or whatever you're using (I like Carb-Medic) you'll see the short term fuel trims take a big drop if you hit a leak with the spray.
