Sponsored by: Auxito
Vacuum leak
Old May 30, 2014 | 02:12 PM
HerbW's Avatar
HerbW
Unhappy Vacuum leak
I am a newbie here and it has been since the 80's that I have attempted to do any work on a vehicle.
Can some one tell me to how do I find a vacuum leak and where is my vacuum canister. I am assuming that it is a vacuum leak for anytime my engine has a load on it the air stops coming out of the dash vents and goes to the defrost vents.
Please excuse my lack of knowledge.
I have an 2000 F150 with the large engine with about 112,000 miles.
Any advise or help is most appreciated.
Thank you,
HerbW
Old May 30, 2014 | 10:59 PM
Dutter 2's Avatar
Dutter 2
nota problem.. But i can tell u this, u dont have a vacuum leak as far as your motor gos. Vacuum is most noticeable at idle, because thats when vacuum is at its highest due to the throttle body being closed. And when u lay in the gas that throttle body opens to let air in and then when vacuum gos down. And if this was the case youd have much bigger problems. But i think i understand ur problem with the vacuum control vet system. What you gota do is find out which vacuum pot is used to open and close the vent to your defrost and dash. Then test them to see if they can expand and retract when u put suction to it or trais down those vacuum lines for a leak. Theres all the input i got good luck,
Old May 31, 2014 | 07:46 AM
projectSHO89's Avatar
projectSHO89
The vacuum reservoir is inside the right front fender.
You do have a mild vacuum leak in the vacuum system that services the climate control. Most common is a cracked or split line near the battery. If you have the electronic climate control, the o-rings in its solenoids often cause the problem.
The individual vacuum motors very rarely are the problem, so spend your time on the common stuff first.
Old May 31, 2014 | 08:05 AM
HerbW's Avatar
HerbW
Vacuum Leak
Thank you all very much!!
Old Jun 3, 2014 | 11:10 AM
cardone's Avatar
cardone
Same problems
I thought I just posted a similar question about 15 minutes ago but I don't see it here. Just as well because I was going to say ignore it because I was wrong.
I'm trying to trace the vacuum line back to the blend door motor to make it operate properly. Starting at the battery box and the small canisters attached to it, I have 19 lbs of vacuum. There are 2 small valves on the firewall near the battery box. They have two (2 each) vacuum lines going into them and each valve has an electric plug on it. I tested the voltage and 3 of the 4 wires have 13.8 volts while on had only 1.3 volts. Is this right or do I have a problem with on of these valves or is this voltage correct, meaning I still have a vacuum leak somewhere.
Once I get an answer to this I can move on to the next phase.
My problem is a lack of vacuum going to the blend door motor. I put a hose on it and drew air out of the motor and the door closed so I'm sure the motor is good.
Old Jun 3, 2014 | 01:35 PM
projectSHO89
The temperature blend door motor is electric, not vacuum operated. Please accurately identify which vaccum motor your concern is with.
Those are your 4X4 front axle solenoids on the firewall. Your voltage readings are normal. One of them is always energized so that one side of the actuator on the front differential always has vacuum.
Old Jun 4, 2014 | 07:39 AM
cardone's Avatar
cardone
Thanks. My issue is air blows thru the defroster and not the floor. I've been told the problem is a vacuum leak that operates the blend door. On the drivers side, up between the dash and floor is what looks like a diaphragm with a vacuum hose on the bottom. That hose goes to a harness of 6 hoses. If I disconnect the hose from the diaphragm and draw air out of the diaphragm, the door closes and air come out the floor. I must have a leak somewhere but it's hard to find. Got advise from several members but I don't quite understand.
1997 F150 4.6L 154K miles
Old Jun 4, 2014 | 09:19 AM
HerbW's Avatar
HerbW
Vacuum leak
Cardone, I stay confused.
Old Jun 4, 2014 | 04:44 PM
projectSHO89
That's not a blend door, it's the vacuum motor for the airflow door that switches between the defroster and the lower half of the plenum.
Yes, you have a vacuum leak as noted in the HVAC FAQs.
Old Jun 4, 2014 | 08:25 PM
steve(ill)'s Avatar
steve(ill)
as SHO89 said there are two systems. There is a motor operated blend door above the transmission hump and under the radio. The variable position damper door adjusts the air temp in the truck........ The other system is "where does the air go".. There are 3-4 different vacuum cylinders that move doors inside the duct to direct the air to the defrost, dash vents, floor, and fresh outside air inlet. There are two controls on the dash. One is TEMPO, the other is LOCATION. WHen you loose vacuum, the doors all spring open and the air goes to the defrost. You can loose vacuum by having a pin hole or crack in the hoses or TEE fittings on the firewall infront of the glove box, or you can have a leak inside the selector **** "valve" on the dash. There are 4 O-rings that seal the ports between the selected locations and vacuum can be lost inside this valve.
Old Jun 4, 2014 | 08:26 PM
steve(ill)'s Avatar
steve(ill)
vacuum system drawing on bottom of page.
https://www.ford-trucks.com/forums/9...-please-2.html
Old Jun 4, 2014 | 08:27 PM
steve(ill)'s Avatar
steve(ill)
vacuum selector valve o-rings
https://www.ford-trucks.com/forums/8...e-defrost.html
blaze 57
Aug 25, 2013 09:03 AM
Luvmifordpu
May 23, 2005 06:27 PM
LV Dan
Sep 7, 2004 03:17 PM
