Testing for vacuum leaks
Old May 23, 2009 | 07:05 PM
johnsf's Avatar
johnsf
I see a few questions on manifold gaskets leaking.first how do you know if it's leaking.What are the symptom's I just put my engine together and it's not running all that great,wondering if maybe I have a leak. I went to the Harbor Freight store today to buy a vacuum test gauge but they didn't have one. When I find one do I check the vacuum at the power brake booster or elsewhere. The engine seems to stumble on the way up but when I hold it at about 2500 rpm it seems to run good,also rougher than normal idle.What's good vacuum 15 psi?
TIA
John
Old May 24, 2009 | 07:06 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Carb cleaner works very well. Spray around carb base, intake and any diff in rpm will show up leaks. Here is the best site I have found for trouble shooting with a vacuum gauge: On Fire
15" of manifold vacuum is alright, more important is that it is a steady reading.
Old May 24, 2009 | 10:49 AM
C-Leigh Racing's Avatar
C-Leigh Racing
Thats some right good imformation on that site, only thing though I'm trying to figure out how I can print those two pages off cause I know I'll forget, but how do you do it & the gauges still move.
Thanks, Neil
Old May 24, 2009 | 12:04 PM
87 XLT's Avatar
87 XLT
Thanks for the link, i just bookmarked it.
Old May 25, 2009 | 07:16 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Thanks, Neil
You can't print and have the gauges move, but you can right click and save to documents. That way you can pull it up and view without being online. I have printed both pages and the info under each pic does explain what is going on. Just not as visual.
One of these day's I'm going to buy a cheap laptop so I can carry my info to the garage.
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
ltyler179
Jan 4, 2015 10:55 AM
Wayno
Apr 19, 2014 07:48 AM
capriceragtop
Oct 3, 2013 05:51 PM
b4hntn
1978 - 1996 Big Bronco
Aug 20, 2011 11:44 PM
