Code 170 and 174 solutions
Old Jan 12, 2016 | 03:09 PM
rick3114's Avatar
rick3114
Unhappy Code 170 and 174 solutions
I have lean code readings on my 98 E-350 super duty 275hp engine. What should I do? I know about the PVA (?) hose and the map clean or replace and places to look for vacuum leaks including the water spray to find intake manifold leaks, but I need more hints and tricks.
Old Jan 14, 2016 | 05:49 AM
JWA's Avatar
JWA
List your engine displacement: ie 5.4, 6.8 etc----more helpful than "275hp"
Typically those codes show a lean condtion, most likely the 90* fitting at the back of the throttle body leading from the PCV tubing. They tend to be covered in a thick insulation so when/if that part cracks its nearly impossible to see without digging a bit deeper.
Dorman and probably 100's of other aftermarket outfits sell that part, like this:
http://www.amazon.com/gp/product/B000QUZ568?psc=1&redirect=true&ref_=ox_sc_sfl_title_76&smid=ATVPDKIKX0DER http://www.amazon.com/gp/product/B000QUZ568?psc=1&redirect=true&ref_=ox_sc_sfl_title_76&smid=ATVPDKIKX0DER
HTH
Alaiex123
6.7L Power Stroke Diesel
Jan 20, 2018 08:33 AM
bigg matt
Modular V8 (4.6L, 5.4L)
Nov 17, 2005 09:25 PM
wresleu
1983 - 2012 Ranger & B-Series
Aug 30, 2004 08:50 PM
2 cowpokes
Jul 5, 2004 04:35 PM
sckent
Aug 10, 2003 10:33 PM
