Bronco II Ford Bronco II
help please
Old Dec 26, 2004 | 02:21 PM
chevma-67's Avatar
chevma-67
Unhappy help please
i have a 2.9L that is running bad it is flooding and lots of black smoke out the tailpipe.I should start by saying its running not bad at idle but will shake and miss everynow and then. It has poor pickup and when it runs bad it will flood the tailpipe with black smoke if you floor it it will clear up if you make a sudden stop it may stall now and then there is no light on dash that is indicating a problem so i dont know if it will show a code if the light is not on all the time and where can i find the codes and jumper method for getting codes thanx.
Old Dec 26, 2004 | 06:41 PM
Ken00's Avatar
Ken00
Check your mail, also run it for a minute and turn it off, pull the vacuum line from the fuel pressure regulator and check for gas, gas = bad FPR.
oldbluethe95
Jun 12, 2011 08:11 PM
4thfordtk
Jan 11, 2007 06:06 PM
Mtneerdan
Dec 8, 2004 07:51 PM
gdcook81
Bronco II
Mar 27, 2003 09:27 PM
sue
1983 - 2012 Ranger & B-Series
Mar 19, 2001 02:28 PM
