Sponsored by: Real Truck
4x4 low clunk
Old Dec 25, 2004 | 12:01 AM
Eric Carroll's Avatar
Eric Carroll
4x4 low clunk
It has just snowed and iced here in mid- tenn, I have had to use my 4-wheel high a bit and my 4-low to pull some people out of bad spots. when I put my truck (04 f-250 v-10 w/8" lift & 38's) in 4-low and go in reverse it seems to slip a bit then make a HUGE clunking metallic sound then hook up. The sound is very loud and scares the hell out of my wallet.This is the first 4x4 with the auto hubs I have had and I dont know if this is normal or if Im doing something wrong, any help will be greatly appreciated. Happy Holidays.
Old Dec 25, 2004 | 04:52 AM
HeavyAssault's Avatar
HeavyAssault
Does the 4lo light come on before you go in reverse??
Old Dec 25, 2004 | 09:41 AM
Eric Carroll
yes, you can hear it actuate after the hubs and it seems to be fine in drive but then in r is will act like only 2wd for a few seconds then clunk! and it starts to pull fine.
Old Dec 25, 2004 | 10:08 AM
HeavyAssault
Could be the normal way it operates. I would have to see if mine does it, I would suggest putting it in reverse, wait a few seconds then light throttle use till you feel it pulling.
Old Dec 25, 2004 | 04:27 PM
Eric Carroll
This also happened; had it in 4lo stopped at inlaws for dinner,left it in 4lo,came out got in truck and it acted like 2wd until I turned the 4wd **** with the truck in n. Is this auto hub stuff just realy sensitive, or mabye a probv with the truck.
zman764
1997 - 2003 F150
Jul 29, 2006 10:26 AM
jlstorm
Jan 4, 2005 08:20 PM
theFabulousmisterG
Sep 2, 2004 08:56 PM
Rainyone
Bronco II
Nov 5, 2003 07:02 PM
