Sponsored by: Auxito
Steering Clunk
Old Jul 26, 2006 | 11:19 PM
zman764's Avatar
zman764
Steering Clunk
I had my 97 4x4 off road the other day. And it may of become airborne a few times. Nothing extreme some watery mud and low semi low speed big bumps that boucne the front end into the air. I have a clunk in the steering column now. The steering wheel and steering is perfectly tight just like always. But on any bump and even accelerating and stopping I feel a clunk in the steering column. Any ideas?
Old Jul 27, 2006 | 03:25 PM
marshall99f150's Avatar
marshall99f150
could be a broken steering column? My buddy had the same problem with his 97 superduty... replaced it (very costly) and it fixed all the steering problems
Old Jul 27, 2006 | 06:39 PM
zman764's Avatar
zman764
there are no problems though. everything operates perfectly. Thes teering wheel doesn't wobble or anything I can just feel a clunk where something in the steering system is moving
Old Jul 27, 2006 | 06:42 PM
BowTieHatr's Avatar
BowTieHatr
do you have to turn a little before it clunks?, or it will clunk no matter what
Old Jul 27, 2006 | 06:44 PM
zman764's Avatar
zman764
the clunk is not related to turning at all. it happens with vertical movement, going over any bumps, or even accelerating and braking.
Old Jul 27, 2006 | 06:48 PM
BowTieHatr's Avatar
BowTieHatr
get under it and have a look while some bounces the truck. your drag link might be bent, one of your tie rods may be loose, idler arm. you should see something hitting. also it could be your steering shaft depending on the severity of the noise
Old Jul 29, 2006 | 10:26 AM
zman764's Avatar
zman764
Its not severe at all. I will take a look and let you know what I find. Everything still functions perfectly.
Skraztastik
Apr 2, 2015 04:41 PM
64rednwhite
Jan 20, 2015 10:18 PM
jkrjlr
1997 - 2003 F150
Mar 24, 2013 12:21 PM
built tough
Sep 22, 2011 12:59 PM
RobH1965
Jun 16, 2010 08:19 PM
