Offroad & 4x4
92 Explorer auto hubs
Old Dec 24, 2004 | 12:42 PM
sjwoody's Avatar
sjwoody
I recently acquired a 92 Explorer with VERY low miles on it from a relative (Dad, we call him). My neighbor works at a ford dealer in parts and said there's a nylon or plastic part in the auto hub that is prone to failure. The replacement has been improved. Does anyone know what this part is and what it's called???
For now it works, but I'd like to do some preventative maintence.
Old Dec 28, 2004 | 03:02 PM
mrshorty's Avatar
mrshorty
If it's the part I'm thinking of, I think it's called a Cam assembly. Do you know what they did to improve it? Is it reasonably priced? Typically it's cheaper/stronger to replace the auto hubs with manual hubs when something breaks, because you have to buy the entire hub assembly. But, if Ford's done something to change that....
Old Dec 28, 2004 | 04:37 PM
sjwoody's Avatar
sjwoody
I'll have to ask him again. It's been awhile since this subject came up, but I had the impression that it was a replaceable part.
Maybe I had my old Suburban in mind when he was describing it. I was able to revive its old auto hubs by replacing a nylon part as well, and I had that picture in mind. I'll let you know...
Old Dec 28, 2004 | 06:39 PM
kspilkinton's Avatar
kspilkinton
The plastic cams have always been prone to failure. The cams wear down or the plastic cracks and the vacuum actuator can fail. When I was the owner of an Explorer for several years I never encountered those probelms with the original equipment. I would have loved to replace them (funds said otherwise) just for the piece of mind.
When you remove the front wheels, the center section stays on. That plastic center is actually the outer housing for the hub locking mechanism. Made me feel uneasy knowing that. I found out when I was rotating the tires and the plastic hub cover fell away from the spindle/rotor with the wheel.
-Kerry
Molineguy
Feb 2, 2011 01:46 PM
knuckle frank
Oct 3, 2004 08:02 PM
93stang
Jun 9, 2004 03:52 PM
Pubert
Mar 4, 2004 10:37 AM
mudduck_25
Nov 12, 2002 12:10 AM
