problem for a 6.0L?
Old Dec 22, 2004 | 02:50 PM
adgillis's Avatar
adgillis
problem for a 6.0L?
My 2005 f250 cc 6.0L is about a month old and I just noticed something that may be a problem. Being completely new to trucks and Fords I wanted to appeal to the knowledge here.
The truck (engine or trans) "burps" (more a pulse than a shudder, and not a serious "buck") several times in the first second after you take your foot off the accelerator following rapid acceleration (to roughly ~30-40mph). This seems to ocurr only when you floor it and then completely take your foot off the pedal AND the transmission hadn't yet reached overdrive. If the truck is in overdrive it decelerates smoothly. The transmission was in normal mode (i haven't tried this in tow mode). Is this to be expected or is it an indication of something that should be addressed or can be improved?
Old Dec 22, 2004 | 03:28 PM
jackofalltrades's Avatar
jackofalltrades
I used to be a software test egnineer. If there's a problem with design, I was pretty good at finding fault.
I'm being outdone here...
I don't have the 5spd automatic transmission, but ya'll that chime it may even edumucate me. (one with a 6spd)
First thing I'd ask is, "What speed does the overdrive come on and go off?" Right around 40-43mph? If you're accellerating hard through the gears then let off right where the computer figures it's supposed to conserve fuel, Do you think it's slightly possible that for that split second that it may shift to OD? But.. you've let off the throttle, and it may actually down shift again? So there's a series of shifting, or not quite shifting, that happens unneccessarily? Is this possible?
Could this be driver induced? Does that make it a design flaw? Run me hard and yank back on the reins, and I might buck too.
That'd be my next test.
I think it best that those with the auto transmission reply to this. Is it normal? I dunno.
Old Dec 22, 2004 | 08:15 PM
beetlebarn's Avatar
beetlebarn
Funny sound
My 05 does this too - from my reading here on this great forum, it is the sound the excess boost being dumped. Not sure of the plumbing arrangement, but it seems to come from the drivers side right behind the seat along the rail.
Old Dec 22, 2004 | 08:31 PM
mark bondlow's Avatar
mark bondlow
I have an '05 ts and when I let off the throttle and hit it quickly, it does the same thing. It is a driver induced problem.
ch1rontl34
Jan 12, 2014 04:13 PM
jlalanas
6.4L Power Stroke Diesel
Mar 24, 2013 01:41 PM
Contingen-Sea
Sep 6, 2011 02:24 PM
kenneBF250V10
Dec 9, 2008 07:53 AM
Twin Tritons
Mar 9, 2004 07:57 PM
