I want to put power steering in it, its got a straight 6 in it, and Hopefully I can put power steering in it. Also will power steering stuff out of a 1980 f150 work in it?
For a 2wd, just get the parts from a 73-79 2wd F100/F150 and it will bolt up. I don't think 80+ will fit.
power steering box with pitman arm
column (power column is shorter than manual column)
p/s pump with brackets for your engine
p/s hoses for your peticular engine
