power steering problem
Old Apr 23, 2004 | 09:20 PM
dave62380's Avatar
dave62380
Unhappy power steering problem
The 390 engine i am going to put in my 83 f-150 does not come with power steering or no places to put the bolts for the brackets for a power steering pump. what is the best thing for me to do?
Old Apr 24, 2004 | 04:15 AM
lastchance's Avatar
lastchance
Sounds like you better head to your local auto graveyard! There are lots of older trucks with the FE engine with power steering. Before you go you might want to check what your engine pulleys look like too. You may need an extra groove in the crank and water pump pulleys too, so you can grab them at the same time. You'll also end up with a better PS pump going with one of the older units.
Old Apr 24, 2004 | 09:28 AM
bremen242's Avatar
bremen242
have fun fitting in an FE motor into a 80s truck.. there isn't any brackets you can put in to make the motor fit.
boss66
Jan 28, 2011 12:38 AM
appel400
Mar 10, 2008 07:15 PM
Bob Crain
May 19, 2005 04:59 PM
62/Unibody
Aug 13, 2004 08:25 PM
cburwell
Oct 23, 1999 03:46 PM
