rear main "how hard"
Old Dec 22, 2004 | 10:13 AM
android7105's Avatar
android7105
I have a 79 f150 400cid leaking oil from the rear main. How hard would it be to replace it. I am mechanically inclined so I am not afraid to do it. Also any other advice regarding it would be great! thanks guys
Old Dec 22, 2004 | 11:29 AM
Bill_Beyer's Avatar
Bill_Beyer
My first advice would be to make absolutely sure it's leaking from the rear main. Valve covers, intake manifold and the ever popular oil pressure sending unit all end up looking like they're a rear main.
Old Dec 24, 2004 | 07:47 PM
android7105
where exacltly is the oil pres.. sending unit? thanks for all ur help
Old Dec 24, 2004 | 08:37 PM
Bill_Beyer's Avatar
Bill_Beyer
The sending unit is on the top back of the block right behind the intake manifold. They're notorious for leaking and then dripping down the back of the motor and looking like a rear main.
Old Dec 28, 2004 | 02:58 PM
good 'ol ford's Avatar
good 'ol ford
make sure its not the rear seal on the manifold either. almost made that mistake once.
Old Dec 29, 2004 | 09:34 PM
fonz's Avatar
fonz
if you decide to replace the rear main seal. jack up the truck and support the frame.that will let the front axle to hang down father. therefore getting you some more clearance. you want it high enough that the tires do not touch the ground.the oil pan will come off .also the oil pump does not need to be disturbed. unless you wanted too replace it.
chewyacura
Feb 17, 2014 10:06 AM
DrewHeil
Mar 3, 2011 09:54 PM
Lead_Pusher
Mar 29, 2010 04:34 PM
Gobstopper909
Dec 29, 2003 06:28 PM
gi_tanker
1978 - 1996 Big Bronco
May 26, 2000 01:03 PM
