Speedometer Noise
Old Dec 22, 2004 | 09:56 AM
jledom's Avatar
jledom
Speedometer Noise
1995 Ford F150 (204,000 miles). Getting a noise that sounds like a water pump bearing going out. Had a new pump installed and still get the noise. Noise stops when I stop and starts again when I get to around 25 MPH. Any ideas as to the source. I am thinking speedometer. Would I replace the whole unit or just the pinion gear and seal?
Old Dec 22, 2004 | 12:46 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by....to help!
Good luck
Enjoy FTE
Old Dec 28, 2004 | 08:27 PM
Paul Crowther's Avatar
Paul Crowther
I occasionally get a sound like the speedo cable is dry. Changes depending on my speed. Not real loud and only once in a while so I'm waiting for something more to happen. Can't help much more than that.
Paul
Old Dec 29, 2004 | 02:50 AM
92supercab's Avatar
92supercab
I am not sure about the F series, but on my 88 mustang I was able to remove the instrument cluster and pull the speedo cable out. I lube it up and put it back in, works great. I don't know if you can do it that way from the tranny side or on an F-series. Might be worth looking into.
Old Dec 29, 2004 | 01:12 PM
qman's Avatar
qman
I don't think there's a speedo cable on a 95. I believe its electronic. Mine is and its a 92.
Old Dec 29, 2004 | 03:04 PM
acerockola77's Avatar
acerockola77
Qman is right - there's a sensor on top of the differential.
Old Dec 31, 2004 | 08:27 AM
Paul Crowther
Mine's an 88. I'll have a look.
PAUL
Mikemakeswine
19
Nov 19, 2017 01:17 PM
1918ALF
Feb 21, 2016 04:09 PM
50trucking
Sep 23, 2014 03:13 PM
50trucking
Sep 8, 2014 07:31 AM
tagunderson
Aug 8, 2004 09:43 PM
