Speedometer Noise
Old Mar 8, 2014 | 02:06 PM
Mikemakeswine's Avatar
Mikemakeswine
Speedometer Noise
Speedometer cable makes noise when driving. As if the gearing is worn. How do you replace. Needle wiggles when driving.
Thanks
Old Mar 8, 2014 | 04:23 PM
MeanGreen460's Avatar
MeanGreen460
Lube speedo cable Unhook from speedo head instrument cluster pull out lube see if it makes a differance
Old Mar 8, 2014 | 04:34 PM
Hopsing69's Avatar
Hopsing69
I would do this as soon as is possible. You can damage the delicate spring movement inside the speedo real easy. If lubing the cable does not stop the dancing of the needle hit the junk yards as I had to do.
Old Mar 8, 2014 | 09:11 PM
Mikemakeswine
Thanks. I will lube the cable. Do I pull it from behind the instrument cluster?
Old Mar 8, 2014 | 09:16 PM
Franklin2's Avatar
Franklin2
You can pull it out from either end. Gravity does help the situation when putting it back in if you do pull it at the cluster.
Old Mar 8, 2014 | 09:22 PM
ctubutis's Avatar
ctubutis
I used white lithium grease on mine, comes in a small toothpaste tube.
Old Mar 9, 2014 | 06:30 PM
MeanGreen460
Unhook from instrument panel push in one side clip to release from speedo head speedo cable will not pull out from unhooking at the trans or transfer case
Old Mar 9, 2014 | 08:15 PM
Franklin2's Avatar
Franklin2
I bet you are correct, it has a little shoulder on it up there doesn't it? Last time I pulled one I did pull it from the cluster.
Old Nov 18, 2017 | 09:03 AM
Rembrant's Avatar
Rembrant
Where exactly do you put the lube? On the square end of the cable, before sticking it in the speedo?
I have my cluster out to install a tach and paint my needles, etc. The speedometer has been making a noise while driving. The needle itself operates nice and smooth and has not been jumping like other reports I've seen on here. Spinning the speedo drive by hand and it seems smooth...
Old Nov 18, 2017 | 09:47 AM
ctubutis's Avatar
ctubutis
The parts that need lubrication are those where friction occurs, this has always been between the cable itself and its sheath in the ones I've seen.
I remove that center cable from its sheath and coat the entire thing in grease before reinstalling it in the sheath.
I have never seen a noisy speedometer head itself but I suppose they can be damaged pretty easily and become noisy (perhaps by somebody trying to alter the displayed mileage) as they're fairly delicate instruments.
Old Nov 18, 2017 | 01:05 PM
matthewq4b's Avatar
matthewq4b
The correct stuff to use on speedometer cables is graphite oil/lube spray. You do not need to remove the cable from the sheath unless corrosion is suspected. Pull the gauge cluster remove the cable by depressing the plastic tab on the speedo head and pull it free from the back of the gauge cluster. Then dribble the graphite oil down the inside of the sheath, use about 1/2 oz.
The graphite in the lube will stay in place and keep the cable lubricated. This is what was used from the factory and what is recommended for all speedo and tach cables..
Old Nov 18, 2017 | 01:30 PM
Rembrant's Avatar
Rembrant
I have never seen a noisy speedometer head itself but I suppose they can be damaged pretty easily and become noisy.
I assumed it was the cable making the noise...or where the cable is engaged in the back of the speedo. No radio in my truck, so I'm hearing things that one might not notice if he had something else to listen to...lol.
OK, thanks Matt, I'll see what I can find. I have lots of greases and lubes here, but no graphite that I'm aware of. Maybe I'll take a spin by Canadian Tire later...no other options really on a Saturday night.
Old Nov 18, 2017 | 01:33 PM
Rembrant's Avatar
Rembrant
Oh...I should have asked. Can I pull the cable out from the dash end and put it back without any issues? Or should it also be disconnected on the transmission end as well?
Old Nov 18, 2017 | 06:45 PM
Franklin2's Avatar
Franklin2
I have done that a couple of times. Sometimes the cable won't want to go back into the gear in the trans and you have to mess with it a little bit. Worst case would be taking the end off the trans and getting it back in that way. But I have never had to do that.
Old Nov 18, 2017 | 08:43 PM
Rembrant's Avatar
Rembrant
I pulled it out about 3" and sprayed some graphite in there. Can't tell how well it is working...I didn't realize how tight the cable is inside the sheathing. I either have to pull the cable completely out, or just try it as is and see how it works. Wouldn't take much to quiet it down...it really wasn't that bad.
