Temp Gauge
Old Mar 17, 2000 | 03:40 PM
jdbeetle's Avatar
jdbeetle
Temp Gauge
My temperature gauge went out about three weeks ago on my '91 Ranger and I'm trying to fix it. My dad and I have replaced the temperature sensor, but it looks like that didn't work. If you have had this problem before or you can help, please reply to jdbeetle(No Email Addresses In Posts!). Thanks.
Old Mar 23, 2000 | 10:01 AM
s0eebuch's Avatar
s0eebuch
Temp Gauge
I recently experienced the same problem on my truck. If you find out anything, please pass that information along.
Thanks!
Old Mar 23, 2000 | 01:34 PM
GregR's Avatar
GregR
Temp Gauge
If you CHANGED the sender and the temp gauge still dosn't work then it's either the wire or the gauge. Check the continuity of the wire from the gauge to the sending unit. NOTE: The sensor dosn't work the gauge it works with the computer to control the choke.The sending unit works the temp gauge.If you changed the sensor instead of the sender the gauge will not work. Hope this helps you.
Old Mar 28, 2000 | 01:25 PM
GregR's Avatar
GregR
Temp Gauge
beckman
Jul 10, 2014 11:39 PM
LARIAT 85
20
Oct 13, 2010 06:02 PM
joe blow
May 6, 2008 09:46 PM
rcknrbn
2004 - 2008 F150
33
Dec 10, 2006 10:31 PM
Tony3
Apr 16, 2004 12:49 PM
