help! temperature gauge not working
Old Apr 1, 2004 | 06:17 AM
Tony3's Avatar
Tony3
Exclamation help! temperature gauge not working
i replaced the coolant temperature sensor and still does'nt work, could it be the temperature sending unit? or the gauge itself?
if you have any tips please help
thx in advance
Old Apr 1, 2004 | 06:48 AM
Rockledge's Avatar
Rockledge
Welcome to FTE!
The Temperature Sending Unit is what you want to check/replace. It's what supplies the signal to the temperature gauge on the dash.
Old Apr 1, 2004 | 09:00 AM
Bob Ayers's Avatar
Bob Ayers
thx in advance
First, welcome to FTE!!!
The "coolant temperature sensor" is the same thing as the "temperature sending unit". Be careful, though, there
is also a ECT sensor next to the temperature gauge sending unit. The ECT sensor is for the PCM, and it has a
2 wire connector on it. The sensor for your temperature gauge just has a single wire connector on it.....
Old Apr 1, 2004 | 04:30 PM
Tony3's Avatar
Tony3
thx for the welcome guys
so if The "coolant temperature sensor" is the same thing as the "temperature sending unit" then that's the part i replaced ,should i replaced the ECT sensor as well? is there a way to test if my gauge is working?
thx for your replies guy
my truck is a ranger 95 v6 3.0L
Old Apr 1, 2004 | 05:31 PM
Bob Ayers's Avatar
Bob Ayers
To test your gauge, disconnect the single wire connector,
and short it to ground. If your gauge is ok, it will go full scale to "HOT". If it doesn't, then your gauge is broke. The ECT sensor HAS NOTHING to do with your temperature gauge.
Old Apr 1, 2004 | 05:34 PM
87 XLT's Avatar
87 XLT
Simple test, remove the single wire from the temp gauge sending unit, shove a nail etc in it and ground it to the engine right beside the sensor. Have someone turn the key to run-not start- & the temp gauge should go to full hot.
Old Apr 7, 2004 | 05:42 AM
Tony3's Avatar
Tony3
Exclamation ?
well it turned out the temperature gauge is broke so instead of me going to the dealer or the junk yard does anybody knows a good website where i can get the temperature gauge? i checked some websites but i could'nt find the part
thx in advanced
Old Apr 7, 2004 | 05:47 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I honestly think this type of part will be a dealer only item with the junkyard being the alternative. If your local junkyard tries to sell you the entire cluster and not the gauge itself, try car-part.com for more sources.
Old Apr 15, 2004 | 07:55 PM
86_XLT_OWNER's Avatar
86_XLT_OWNER
Hi guys,
I've had trouble with my gauge as well and tried 87 XLT's suggestion. The Gauge went to full hot.
Faced with changing the sender, I was wondering if mechanical gauges are better/more reliable than electric ones?
Old Apr 15, 2004 | 08:26 PM
Diabolic's Avatar
Diabolic
I am also having the same problem, my sending unit actually has 2 wires i believe, because the new one i bought looked the exact same as the old one. But now every once in a while after running for apx. 40 mins, i'll see it jump to where it should be, and shortly after, drop again.
Old Apr 16, 2004 | 03:30 AM
87 XLT's Avatar
87 XLT
Originally Posted by 86_XLT_OWNER
Hi guys,
You wont gain anything with an aftermarket temp gauge, i'd just replace the sending unit for 6 bucks.
Old Apr 16, 2004 | 12:40 PM
Ken00's Avatar
Ken00
The 2 wire sensor is the ECT, for the computer, the sensor for the gauge only has 1 wire.
Old Apr 16, 2004 | 12:49 PM
stepman's Avatar
stepman
Tony, before condeming the guage, try running a wire from the backside of the gauge to ground. See if you can make it peg from there. You could also have a wire problem in between....Grounding it at the sender checks the gauge AND the wiring to it.
JD_F100
26
Aug 31, 2014 10:26 AM
MC Dig
Jan 31, 2012 08:50 AM
Kez
Nov 19, 2008 05:48 AM
PaulzF150
Apr 1, 2008 02:57 AM
charmedaz
Jul 3, 2006 09:28 AM
