I have a 2002 Supercrew (4x4) and I'm thinking I may need to turn or replace my front rotors. I only have 26K on the rotors but I think there warped. I think this because when I apply the brakes I get a vibration through the brake pedal. I've replaced rotors before but never on a 4x4, is it allot more work to remove rotors on a 4x4?
Hey ZoomingM3.
It is not that hard. After you remove the tire you will need to remove the caliper. Next remove the brake caliper mount. Now you can with luck, tap the rotor off. If not you might need a puller. good luck.
