Removing bed from Ranger...Procedure? How difficult?
Old May 26, 2000 | 08:50 AM
allengoodwine's Avatar
allengoodwine
How difficult is it to remove bed? What is procedure? What problems might I encounter because it is old (85)? IYHO...Is this the best way to get to in tank fuel pump/filter? Thanks for your help. Allen
Old May 26, 2000 | 09:19 AM
Motorcraftsman's Avatar
Motorcraftsman
if your trying to remove your bed you will need to undo the wirring to the tail lights, any exhaust brackets bolted to the bed, gas filler tube, any other obtacles, then the bolts that hold the bed to the chassis, the have a few men help you lift the bed of off the truck, if your trying to get to the fuel pump and stuff just drop the gas tank, its much less work than pullinng off the bed.
Old May 26, 2000 | 12:45 PM
Mikeman's Avatar
Mikeman
Haoleman
Nov 4, 2008 11:49 AM
nofortunateson
Bronco II
Dec 29, 2007 10:44 AM
clintbonnie
Mar 7, 2006 06:34 PM
cwt580
Dec 27, 2005 09:01 PM
icy_wolf
Mar 26, 2002 03:27 PM
