Bronco II Ford Bronco II
Ford 2.9 head bolts...
Old Dec 27, 2007 | 08:10 PM
nofortunateson's Avatar
nofortunateson
What size wrench does it take to remove these. Aren't these allen heads? If so, what size allen socket? Thanks.
Old Dec 27, 2007 | 08:57 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I was thinking my 1988 wasn't Allen Head. Just a regular 6 sided metric bolt head. I can't remember the size but they are not reusable. Torque to yield bolts or something like that.
Old Dec 28, 2007 | 01:52 AM
Help I M Stuck's Avatar
Help I M Stuck
T-55 if I remember correctly.
Old Dec 28, 2007 | 01:18 PM
my72ford's Avatar
my72ford
Jeff is correct.. it is t-55 and do not reuse the old bolts,get new ones when putting heads back on and follow torque specs
Old Dec 29, 2007 | 10:44 AM
ToughNut's Avatar
ToughNut
T-55 and a breaker bar and YES the bolts are stretch bolts you can not reuse them or they will break. Also when torqing them down go with the specific torque sequence or your head gaskets will leak. 2.9's are notorious for leaky heads as it is.
[8] [1] [4] [6] first stage goto 22 ft.lbs.
[5] [3] [2] [7] second stage to 52-55 ft. lbs.
You need to wait for the final step to allow the bolts to stretch a little. 5 minutes is a good rule of thumb so I then do the other side the same way then go back to the first head and turn each bolt in the same sequence an additional 90 degrees. Then do the second head. Hope this helps.
~Tough
largefries
Sep 7, 2012 08:37 PM
zrt600guy
Escape & Escape Hybrid
Oct 22, 2011 08:28 AM
Shaneb75
May 10, 2011 06:15 AM
wrench11
Sep 18, 2009 11:44 AM
