Sponsored by: Kumho
Brake lines Size
Old Dec 20, 2004 | 04:15 PM
zzjonze's Avatar
zzjonze
Brake lines Size
Can someone tell me what size flare nut wrenches do I need to get all my brake lines off my 1987 XLT Lariet 4x4. ( It is Canadian made)
I will need to be buying the wrenches but don't know if they are metric or SAE.
Any advise would be helpful.
ZZ
Old Dec 20, 2004 | 09:19 PM
mark a.'s Avatar
mark a.
You could try the fittings with a combination or open end wrench. Maby they will come right off.
Old Dec 20, 2004 | 10:43 PM
zzjonze's Avatar
zzjonze
I would try that if I had the truck here at my house LOL!!.. But it isn't
Thanks anyway Mark.
Old Dec 20, 2004 | 11:08 PM
rebocardo's Avatar
rebocardo
Since you probably drive on salted roads there is a good chance no matter what you do, the lines will be destroyed getting the lines off because the nut will be welded to the steel line because of the salt.
Really soak it in PB Blaster, apply a little heat if you are replacing the wheel cyl. anyways, and use with a good flare nut wrench or a good crows foot wrench to remove the fitting. Wiggle the fitting back and forth while spraying and do not try to twist it right off if it is stuck, you will crack the line.
Snap-On is one of the best choices for these tools, but, since you are asking the question I would assume you need it for a one or two time use, so I would go Craftsman and skip the cheap ones at Autozone. Northern Tools sells them an inexpensive set, though I have not bought the flare wrenches from them.
Old Dec 21, 2004 | 07:52 AM
zzjonze's Avatar
zzjonze
Thanks for the replys.
Yes, I imagine too all the brake lines will have problems in getting them off. The Truck came from Iowa and there is alot of rust. So that is the reason I thought I should replace them all. I don't want future problems especially stopping.
Thanks for the info.
SPreston2001
Mar 21, 2020 05:04 PM
SWA2004
2004 - 2008 F150
Mar 26, 2010 08:41 PM
oldcoupe42
Jul 24, 2007 06:24 PM
LLOYDJOHN
Sep 23, 2006 12:27 PM
seagull369
Garage & Workshop
Apr 8, 2006 02:59 PM
