Sponsored by: Kumho
lift kit
Old Dec 15, 2004 | 05:42 PM
straight6beast's Avatar
straight6beast
lift kit
looking for a lift kit for an 88 f 150 2wd can anyone help looking to go 2-3 " wanna slip a set of 31 or 33 sneakers under it
Old Dec 15, 2004 | 05:45 PM
qman's Avatar
qman
I have a 92 4x4 with a 2.5" lift and 33s fit fine. I can probably fit 35s. You don't need much of a lift to put in a bigger tire. If your truck is stock you can probably already put in 31s without much trouble.
Old Dec 15, 2004 | 08:12 PM
straight6beast
i am running with 235/75 r15's right now but have mabye an 2 inch of clearance in the front the rear has 3-4 without load
Old Dec 15, 2004 | 08:25 PM
natewoz's Avatar
natewoz
Tuff Country / Rough Country has a 2.5" kit, I have the 4x4 version on my truck. Like it except for the eccentric cam bolts. Also a body lift would cost about
$80-90 and let you clear 31" no problem, and probably 32's. When my truck had just a 3" body lift, I could fit 33's, but mine is a 4x4 and is 2" taller. I would reccomend doing a body lift if you want to fit bigger tires without a lot of investment. On the other hand, once you start lifting and modifying, you always want to go bigger, so keep that in mind when you make your descision. Have fun.
Old Dec 19, 2004 | 12:10 AM
straight6beast
see i can lift the rear no prob its the front that is stumping me is it posible to just put in taller coils? or have the stock coils stretched the 3"
Old Dec 19, 2004 | 11:02 AM
crack's Avatar
crack
can you get coils stretched?
Old Dec 21, 2004 | 08:18 AM
king1884's Avatar
king1884
www.broncograveyard.com has a 4x2 lift kit that I am looking at for my truck.
