Metric flare wrench question
Hi folks. Ive been looking for a cheap set of metric flare wrenches in case I run into any metric brake line screws while working on the car. The ones Ive seen in auto-zone, advanced auto skip the odd millimeter sizes. In other words in a set of 4 wrenches one wrench will be 8mm & 10mm, the next will be 12mm & 14mm, etc, etc.
Is there a reason why there are no odd ones in the pack? Do automotive brake lines not generally use these odd numbered sizes? Ive noticed more expensive brands like craftsman/ mac/ snap on DO come in odd sizes, so this is confusing me.
Appreciate any thoughts.
Personally, flare-nut wrenches are one of those areas where "cheap" should be avoided.
I bought a set of cheap Autozone flare-nut wrenches and regret it everytime I have to use them... I think they're metric too... This opinion gets driven home even more so whenever I use the sole K-D 3/8-7/16 wrench I have that was bought years ago. The tolerances are so bad on the cheap wrenches that I often end up using a standard open-end wrench because it grips better.
This is one situation where I can justify Snap-on. Also, Snap-on seems to be the only company that offers the rather convienent flare-nut/open combination wrench.
I agree 100%. I posted a picture here a while ago where the Autozone 18 mm one broke while trying to do a simple A/C fitting on a Chevy. The cheap ones are better then nothing, sometimes, that is about it.
If it was needed for a vital part, I would go Snap-On or Mac.
While acknowledging the above wisdom that quality co$t$, my inner tightwad compelled me to make my own when I needed one in 10mm. I priced a set at Sears and gagged---can't part with that much cash for something used only once in a while. So I picked out a sturdy-looking combo wrench on my next visit to the local used tool emporium. Took it home and used a cutting wheel to open a slot just large enough to slip over a brake line. Presto, flare wrench. If it spreads, I'm out 50 cents.
I was looking for a set, in a high theft risk, environment. The older style Craftsman was known to spread, they came out with the newer polished style, and increased the head size. But another one I looked at, that a few people said was one of the better import tools, V8 tools, flare nut/open end combo wrenchs, over at thetoolwarehouse.net.
Damn, 1stoldtruck, what a freagin' good idea. I have tons of spare closed wrenches in storage. Ill break out my dremel w/ cutoff wheel and get grinding. Im sure you snap on/ mac users are scoffing at this idea, but it's a tightwad thing
Thanx for the idea, and to all others who've replied.
