Does anyone out there know of a relativelly easy method to reduce the turning circle of an F250SD Crew. Wheel offset, spacers and alike.
I', tired of having to drive around the block to get into a parking space. Love the truck though. Won't part with it.
The only method I know of: buy the 2005 or newer version of the same truck. They drastically reduced the turning circle with the new coil spring suspension.
The turning radius is reduced by approx 16% down from 54 ft on the 05.
Smaller skinner tires, removing the steering stops, and cutting a section out of your frame and shortening your wheelbase would effectively lessen the turning circle. I do not advise any of the aforementioned modifications.
