Howling from Air Intake?
Old Dec 20, 2004 | 07:53 AM
Schuby's Avatar
Schuby
Unhappy Howling from Air Intake?
Did anyone ever find the answer to the howling intake problem. I have read the other posts on this issue but no definite solution to fix it. I am getting the howling too. I have had my air intake over a year now & it just started doing it a couple of months ago, very seldom, but seems to occur more since the weather is getting colder....I have a 2000 F-150 4.6L manual tranny. Any help would be great.
Old Dec 20, 2004 | 05:45 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I had to put the little black vacum box back on to get rid of my howling.
Old Dec 20, 2004 | 09:51 PM
Schuby's Avatar
Schuby
So did that get rid of the howl for good? I assume you have some kind of aftermarket intake, I was wondering how you rigged your hose from the little box to your intake pipe. My intake has the hose from the box going into the intake pipe between the air filter & the intake elbow. Thank you for the info....I will put the box back in......hopefully this will do the trick.
Old Dec 20, 2004 | 10:25 PM
97Centurion
Rub my Belly
Yes I have a Volant intake. I had to remake the box so it would line up with the intake. I'll get some pics loaded so you can see what I am talking about. The noise did go away for good!
Old Dec 21, 2004 | 08:24 AM
Schuby's Avatar
Schuby
Thanks Tony....that helped a whole lot.....I will rig up my black box & put it in..
Old Dec 23, 2004 | 09:49 AM
keith0404's Avatar
keith0404
does this howling happen only around a certain RPM.. mine makes a simliar noise around 2300 rpms at around 40-50mph going uphill.. i was just wondering if this was the source of the howling noise.. btw, i have a 2001 F-150 4.6L v8
Old Dec 23, 2004 | 03:50 PM
97Centurion
Rub my Belly
Mine did it at idle mainly and up to about 1500 Rpm.
Old Dec 23, 2004 | 04:08 PM
Schuby's Avatar
Schuby
it did it mainly at idle...or sometimes when I was slowing down
Old Jan 3, 2005 | 09:39 AM
Schuby's Avatar
Schuby
What did you use to modify the black box ?
Old Jan 3, 2005 | 04:30 PM
97Centurion
Rub my Belly
I relocated on of the fittings. Used a plastic one that I bought at the hardware store. I also cut the slanted part a little deeper. To plug the old fitting hole and replace the slanted part I cut off, I used an old tupperware lid. Cut to fit. Used JB weld to hold it all together
radck
Oct 30, 2016 04:01 PM
niceguy4872
Aug 14, 2014 06:12 PM
Skips97
Jul 17, 2007 04:32 PM
alfy007
3.0L V6
Apr 19, 2004 01:12 PM
hang10
Modular V10 (6.8l)
13
Jan 12, 2004 10:29 AM
