Elec. Problems, My answer
Old Dec 20, 2004 | 07:51 AM
jwirth's Avatar
jwirth
I had a long fight trying to figure out why my truck didn't always want to start and cranked very poorly. Replaced battery, alternator, starter. Checked and rechecked the cables.
However, even though the negative cable looked fine, it wasn't. I got a new, heavy cable, made sure it made good contact with the engine block, and shazam! No more starting/charging problems.
If your cables are old, try new ones. They're cheaper than alternators and starters!
Now to that pesky 'light switch kills the engine' problem!
Old Dec 20, 2004 | 04:00 PM
mark a.'s Avatar
mark a.
You should also add one from the block to the frame.
Old Dec 20, 2004 | 04:10 PM
jwirth's Avatar
jwirth
Heck yeah, great idea!
Old Dec 20, 2004 | 05:23 PM
V10KLZZ71S's Avatar
V10KLZZ71S
My 74 w/302 headers,always had hot start problems.Changed both cables w/bigger ones-walla no more slow cranking.
Old Dec 30, 2004 | 12:14 PM
RDON's Avatar
RDON
I had a problem with a 77 car. Groung strip on the fram,But it was not conected to the motor. Problem solved
Old Dec 31, 2004 | 12:00 AM
Torque1st's Avatar
Torque1st
Posting Legend
The OEM neg cable had a special ground tab that is not on replacement cables. Cables often go bad inside the end connections and the fault is not visible. Voltage measurements across the connectors can usually determine the location of the fault. Also the bodies on these old trucks are laden with rust and the ground connections are often bad.
Old Jan 2, 2005 | 03:53 PM
twolls's Avatar
twolls
I agree, new cables make a heck of a difference. And you can plan the work for a free afternoon instead of begging for a jump or a push, at the worst time, while your at the store, in a crowded parking lot, running late, in the dark, while it's raining,.....
Old Feb 2, 2005 | 06:06 AM
nayr's Avatar
nayr
why would the light switch kill the engine. did you get this problem solved.
Old Feb 2, 2005 | 07:27 AM
jwirth's Avatar
jwirth
Well, since I hardly ever drive the truck and since it hasn't done it since, no, I didn't solve it. In fact, when I drove it recently, the horn started to sound by itself off and on. I had to pull over and disconnect it.
I have yet to diagnose further.
fatherdoug
Aerostar
15
Nov 20, 2006 12:39 AM
ironelk
Electrical Systems/Wiring
Dec 3, 2005 10:29 PM
51PanelMan
29
Oct 20, 2005 09:42 PM
neednewranger
1983 - 2012 Ranger & B-Series
19
Jul 20, 2003 10:55 PM
BigAndPrimed
May 2, 2003 09:24 PM
