So confused!!!
Old Dec 19, 2004 | 12:01 AM
352 blue's Avatar
352 blue
So confused!!!
Ok Carolina classics sells a floor pan that it says fits a 65-79 but then it says oversize. Neither LMC, NPD, or Mac's sell a floor pan for a 65-66 but they sell a 67-72 floor pan, NPD says it is 29" wide will this fit my 66 will I have to trim it to size?????????
Old Dec 19, 2004 | 06:27 AM
jowilker's Avatar
jowilker
Hi Scott, The floor pans are the same from 65-79 with an exception of a flat strip added at the back in 73 for a cab extention.
I think I have heard that these replacement parts fit over your existing.
good luck finding what ya need
John
Old Dec 19, 2004 | 07:58 AM
ddavidv's Avatar
ddavidv
I'd recommend you call Rick at Carolina Classics and ask him. I'm pretty certain he has those pans made just for himself, and he will be able to tell you what the deal is.
Old Dec 20, 2004 | 06:15 AM
jowilker's Avatar
jowilker
Dwight, Not a bad idea to talk to Rick anytime. His pans are for the 61-64 trucks. I am pretty sure that it was he that told me about the fit over.
John
Old Dec 27, 2004 | 05:00 AM
dads truck's Avatar
dads truck
John
Do you have the address and phome number of Carolina Classics as I am in need of floor pans for my 64 M100.
Thanks Phil
Old Dec 27, 2004 | 05:35 AM
jowilker's Avatar
jowilker
Sent ya a mail Phil.
John
Old Dec 30, 2004 | 04:42 PM
AgH's Avatar
AgH
I bought floor pans for my '66 F-100 from I believe Mac's that stated to fit a '66. When the box arrived it was marked for '67-'72. I did alot of measuring before I started cutting out my old floor pans. The new pans had an extra lip on the sides, top and bottom edges, which turned out to be great. I only had to cut out the bottom of the pans since the walls were still good. The new pans fit right in and over lapped on the sides. I only had to cut off about 1/2"-3/4" on one side and on the top of the driver's side to go around the steering column. It was easy to cut with a metal blade in a reciprocating saw. I took some photos of them going in if that'll help.
Good luck.
66f250
13
Apr 3, 2013 07:59 PM
6fifty_f1fifty
Dec 4, 2010 09:46 PM
taylorjgreen
Sep 7, 2008 09:11 PM
falcon1964
Jul 11, 2007 07:36 AM
swilms
Jul 21, 2005 11:03 AM
