1978 - 1996 Big Bronco
Door wIRING
Old Dec 18, 2004 | 04:32 PM
svtgtcobra's Avatar
svtgtcobra
Question Door wIRING
I am doing wiring right now, and i cannot seem how to get the wire into my door for my speaker...i know theres a black tube that has wires thru there, but i cannot seem to snake it through, any hints, or what to disconnect to make it be able to go thru...i have a 1994 ford bronco XLT...
Old Dec 18, 2004 | 04:48 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Moved...
Enjoy FTE
Old Dec 20, 2004 | 01:40 AM
greystreak92's Avatar
greystreak92
The rubber tubing is most likely the actual problem. Being convoluted like it is the wire ends tend to hang up inside. Best bet would be to pull it from the door carefully (like you would a rubber grommet since thats how its secured in the door) and if you can't fish it through with your fingers, try a piece of stiffer wire than the speaker wire. Make certain that you secure the heavy wire to the speaker wire by looping the ends of each around the other and taping the joint. Then bend the end of the stiffer wire over and tape the end you are pushing through so the wire doesn't punch through the side of the rubber before it gets through. Just a couple of tips that may make the job a little less stressful.
GlennTX
2009 - 2014 F150
Dec 14, 2016 10:50 AM
shagwill
Sep 24, 2011 07:19 AM
Silverdawg
Dec 7, 2010 04:22 PM
switchback
Electrical Systems/Wiring
Aug 20, 2003 06:30 PM
PrPlayboy
May 24, 2003 07:51 PM
