strange radio problems!
Old Aug 20, 2003 | 05:44 PM
switchback's Avatar
switchback
Question strange radio problems!
Hello. I have a 98 F-150 supercab, 4.6 liter, 5 speed 4 x 4, with am/fm radio with the 6 disk CD player in the panel behind driver door. Today I totally washed the inside of cab by removing all seats and using carpet cleaner, brushes and then spraying with a hose to clean the carpet (it was FILTHY) Ok, I let everything dry (though carpet is still damp) , replace seats and noticed this:
* radio will only play the station I was listening to while washing inside of truck - volume works fine
* I cannot change radio am to fm, change channels or play CDs
*there is no panel light on the radio. It is totally dark and doesn't show channel or clock
* if I turn key and try to play radio, it won't play unless I quickly switch on then off the windshield wipers.
* the rest of truck seems to function well
Ok, I went thru my owner manual but can't figure out what is going on here. Any help will be greatly appreciated!
Old Aug 20, 2003 | 06:30 PM
mantta's Avatar
mantta
After everything dries out it will probably work fine. You might have got a bit of water in it or, the humidity in the cab while you were washing it condensed inside the radio.
oldbleu
Jun 15, 2024 01:14 PM
judge26
2009 - 2014 F150
Oct 3, 2017 03:03 PM
eagleeyes50
15
Jun 1, 2016 10:09 PM
wrhatt
Mar 30, 2016 06:34 PM
Satch
1997 - 2003 F150
Jan 29, 2016 07:35 PM
