fuel system problems
Old Dec 18, 2004 | 01:13 PM
jeff white's Avatar
jeff white
i own an 89 f-150. been having fuel problems. it bucks, hesitates while driving. i replaced fuel pump, filter, plugs, wires, cap and rotor. it idles ok and starts fine. just when i drive it acts up. any suggestions would be appreciated
Old Dec 18, 2004 | 02:35 PM
jeff white's Avatar
jeff white
this truck is an 300-6cyl
Old Dec 18, 2004 | 06:15 PM
mike L's Avatar
mike L
Welcome to FTE. Sounds like you need to check the fuel pressure to. Which fuel pump did you replace. Do you have two fuel tanks that work? I'm no expert but I would check for trouble codes to. See www.fordfuelinjection.com under getting trouble codes. Its easy and free. Also your Haynes manual has a ECC trouble codes section. Let us know if you get any codes.
Merry Christmas,
mike
Old Dec 18, 2004 | 06:32 PM
jeff white's Avatar
jeff white
i took it to a garage and the mechanic said it had 42 lbs, i replaced the pump in rear tank, front tank no longer in truck.
Old Dec 18, 2004 | 06:35 PM
WALJON's Avatar
WALJON
Could be a number of things but checking the codes is a good idea,I too had a problem like this on an 89 f150 302 turned out it was the plenum gasget it was ripped and leaking air It would idle ok and start good but soon as I would start driving I would have the same symptoms as you, funny thing too the check engine lite never flashed at all good luck
Old Dec 18, 2004 | 06:42 PM
jeff white's Avatar
jeff white
tks i'll try that
Old Dec 19, 2004 | 09:01 AM
jeff white's Avatar
jeff white
could it be the TPS switch. a mechanic friend of mine to me to try that. what is this and what does it do. is this a hard thing to change.
Old Dec 19, 2004 | 09:34 AM
WALJON's Avatar
WALJON
Is the check engine light flashing? (when you are driving)
Old Dec 19, 2004 | 09:39 AM
jeff white's Avatar
jeff white
yes it flashes after about 20 minuites of driving
Old Dec 19, 2004 | 09:41 AM
jeff white's Avatar
jeff white
the check engine light comes on after about 20 mins of driving
Old Dec 19, 2004 | 09:52 AM
jeff white's Avatar
jeff white
could i have to much fuel pressure i changed fuel filter twice, the mechanic said it reads 48lbs. is that to much pressure, do i need to bleed the system
Old Dec 19, 2004 | 10:01 AM
tmcalavy's Avatar
tmcalavy
Pull the codes
The fact that your Check Engine Light comes on indicates something has set a fault/trouble code with your truck's computer. Best way to proceed is to pull the codes, or have your mech pull/read them. That will isolate what is wrong, so you don't spend mucho bux throwing money at the problem without knowing which system is causing the fault.
Old Dec 19, 2004 | 10:59 AM
jeff white's Avatar
jeff white
codes 33, 29, 42 are the major ones coming up just checked it
Old Dec 19, 2004 | 12:56 PM
mike L's Avatar
mike L
codes
(O) = Key On Engine Off test
(R) = Key On Engine Running test
(M) = Memory code
29 Vehicle Speed Sensor problem - VSS
33 ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
42 (R) System rich - Fuel control
(M) System was rich for 15 seconds or more (no HO2S switching) - Fuel control
Were these codes while engine was running? Or was after it was warm and not running? Which engine do you have? 35 to 45 psi for fuel pressure is ok with engine off, if it's not a 4.9. 42 psi is ok, 48psi is to much, with the engine not running, which one did you mean? Was this reading while running? Is that why you replace the fuel pump? Give us the other codes to. Start testing the sensors with the lowest code first. Don't just replace parts, ok. Does it run bad on both tanks?
Old Dec 19, 2004 | 01:19 PM
jeff white's Avatar
jeff white
ok first codes when tk wasnt running are13,42,52,77. while running are13,29,33,42
