98 Ranger Alignment problems
Old Oct 29, 2000 | 09:52 PM
bobfl's Avatar
bobfl
I have a 1998 Ford Ranger that will not stay aligned. It has ruined the tires (Firestones, so
maybe it's not a big loss). Someone had mentioned to me that the Rangers had problems with the front end and there is an add-on kit to adjust the camber. He did not seem to sure about what he was saying, so I looking for more info. Does anyone know if there is a problem with the front ends or about the additional kit to be able to adjust the camber. I was not aware that this would be necessary.
Thanks
Bob W [FL]
Old Oct 29, 2000 | 10:06 PM
bobfl's Avatar
bobfl
>(Firestones, so
>Thanks
>Bob W [FL]
I should have mentioned that this is a 2 wheel drive truck with a 3.0L automatic
Old Oct 31, 2000 | 06:14 AM
ven0m's Avatar
ven0m
My 97 killed it's first set of tires with fairly even wear at about 36K Whihc for the firestone power puff's that come ona 2 WD ranger I thought 36 was about all that I could ask for the way I drive. I got a decent dela on some 50K rated Bridgestone's from Sears and they have performed fine for me. I will say that if you are due for a rotation (about every 6 - 8K) you will notice the truck start to pull during moderate braking. But my tires have worn just the way I expect them too.
Old Nov 1, 2000 | 07:19 PM
jopey's Avatar
jopey
Duzzi
Jan 7, 2016 01:25 PM
94GreenTruck
1997 - 2003 F150
Dec 17, 2014 09:25 PM
vbxt
Jul 26, 2011 09:16 PM
garvicmos
2004 - 2008 F150
Mar 7, 2009 09:32 AM
waverous
Aug 25, 2005 10:45 PM
