Rear End Ratio
Old Dec 18, 2004 | 07:30 AM
eldomike's Avatar
eldomike
Rear End Ratio
I have a 1991 E350 High Top Van with the 7.3 and E40D tranny....it has 3.55 rear gears....I bet this thing will run the Ton but since I pull a trailer and would rather run 60-65 I'm thinking I should look at getting a 4.10 or something rear end...I'd like to be able to pull the hills better...watcha think?
EldoMike
Old Dec 18, 2004 | 08:47 AM
ditch witch's Avatar
ditch witch
"....I bet this thing will run the Ton but since I pull a trailer and would rather run 60-65 to pull the hills better...watcha think?"
I'm missing something here. Rephrase your question and you'll probably get an answer that will help ya.
Old Dec 18, 2004 | 08:51 AM
eldomike's Avatar
eldomike
hmmm....sorry.
My van will run high speeds but with little power....would like to have more pulling power for hills..should I get a 3.77(?) or 4.11?
Old Dec 18, 2004 | 09:05 AM
ditch witch
I've got a PU, not a van, however same problems when it comes to gearing. My truck had 4.10's and it would pull anything. BUT- I only use it to pull a trailer maybe 5-10% of the time. AND, I never used 1st gear to start out. (I do have a 4 speed T-19, as opposed to your auto). A month or so ago I switched out the rear for 3.54 L/S. It still has plenty of torque, and I still don't need 1st if I'm empty. Engine runs much slower, cab is quieter, fuel ecomony is up--everything I was wanting. And, Oh, I don't get stuck in a heavy dew!!
If you want a happier medium go for 3.73.
Old Dec 18, 2004 | 12:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
eldomike, with 3.55 rear end gears and 31" tires you should be running 117 MPH at 3200 in OD.
If you drop it to 4.10 gears you will still be able to see 101 at 3200.
At 2000 RPM you should be running about 73 MPH with what you have.
4.10 gears will put you at about 63 MPH at 2000 RPM.
Old Dec 18, 2004 | 02:45 PM
eldomike's Avatar
eldomike
I have 31" tires...yep, that sounds about right...believe I'll go with at least some 3.78's...
EldoMike
Old Dec 18, 2004 | 03:14 PM
patriottow's Avatar
patriottow
I have 90 F350 7.3 with 4/10 rear 16 inch tires .2000 rpm=63 mph =13 mpg.I tow cars all dat and found the 4/10 to be great!Milage sucks but i can pull any thing.Fuel prices in Omaha Ne is 2.06 now and have been 2.38 a gal and i have thought about changing gears if prices go up.
Old Dec 18, 2004 | 04:27 PM
eldomike's Avatar
eldomike
Thanks for the feedback everybody...BTW, fuel is 1.89 here in West Tn today....bought it for 1.79 in Alabama earlier this week...
Old Dec 18, 2004 | 05:52 PM
eldomike's Avatar
eldomike
....I guess I could also just run it out of OD when I'm pulling a trailer...that way I'd have the better ratio when I'm not pulling...
eldomike51
Dec 4, 2015 04:16 PM
eldomike
Mar 3, 2005 05:07 PM
eldomike
Aug 30, 2004 06:08 AM
eldomike
Mar 7, 2004 06:18 PM
