Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Compressor Advice
Old Jan 24, 2005 | 05:12 PM
Crash687's Avatar
Crash687
Originally Posted by Gil Chesterton
Does anyone know the merit (or downside) of coupling a 60 gal tank to any of these smaller units? Would the extra storage be worth taxing the motor on the smaller unit?
actually the compressor will have longer cycle times(more time for cooling), make sure the secondary holding tank is at the same pressure of the tank on the compressor and put the regulator on the output of the secondary holding tank. alot of small package air compressors have a regulator on the output of the built on tank, either bypass it or crank it all the way up and run it into the secondary tank.
Old Jan 24, 2005 | 07:25 PM
fixnair's Avatar
fixnair
Smile
Actually Gil, increasing the storage size is of little benefit. While it is true that the off cycle will be a tad longer, the on cycle will be correspondingly longer negating any cooling effect.
The largest I can find available commercially is WW Graingers 2HP 115v, 15amp, 5 CFM @125 PSIG, for $399.00 US. These numbers are real. That is they conform to ASME standards. Remember too that CFM goes down as the pressure is incresed. My 5CFM @ 125PSIG will probably expand to 6 or 7 @ 90 PSIG
Hope you find what you want.
Old Jan 25, 2005 | 09:20 AM
Gil Chesterton's Avatar
Gil Chesterton
Thanks for the input. I'd heard both sides of the argument (as "fixnair" and "crash687" have demonstrated).
Anyone else?
I'll look at the Graingers too, thanks. I've never heard CFM described at 125 before but you're right that it would translate into about 6-7 at 90.
jecsd1
Sep 8, 2008 04:01 PM
jecsd1
Paint & Bodywork
Sep 4, 2008 06:35 AM
F250Rob
Nov 21, 2004 11:10 AM
Ford79
Garage & Workshop
Mar 3, 2003 10:01 PM
seebeew
Paint & Bodywork
Sep 13, 2002 01:35 PM
