cant figure it out
Old Dec 13, 2004 | 08:25 PM
FORD60's Avatar
FORD60
cant figure it out
iv got a 351m 40 over it had a blowen head gasket so i replaced both of them and intake,headers etc.. fired it up and test drove it ran pretty good the next day i went running around and the oil pressure dropped (dummy gaudge) it was running like crap then i heard a knocking it sounds like its coming from the front of the motor we turned the crank and watched the rotor before it was fired it didnt seem to be streched any advice what range should the compression be when runing a test? thanks for any help
Old Dec 14, 2004 | 09:29 AM
mark a.'s Avatar
mark a.
There should be more than 100 p.s.i. in each cylinder. more like around 140 p.s.i. would be ok.
Old Dec 14, 2004 | 08:13 PM
78 stepside's Avatar
78 stepside
when i tested the compression #1 cyclinder was 100 psi the next one was only 80 psi that was cold.. the truck sat outside im 35degree weather then i warmed it up and it got worse #1 dropped to 85 psi and the next was 65 psi im not to shure how good the tester is i am going to get a new one tomarrow and check it again after that i am going to pull off the timeing chain cover and look that over but after i get those chores done i will let ya know how it goes
Old Dec 14, 2004 | 11:56 PM
grclark351's Avatar
grclark351
make sure you have the throttle held open during testing. to avoid flooding the engine, just wedge a screwdriver in the linkage somewhere. this allows the cylinders to get all the air they want to compress for the test. take all the plugs out before you start too, this will allow the engine to spin more freely and not pull down your battery and starter so much. if you only had 80psi in each hole it would be OK, not real good but OK. what's bad is when there is a big difference between the highest and lowest.
Old Dec 15, 2004 | 09:03 PM
78 stepside
i didnt get a chance to mess with the truck today but thanks for the info on the throtle and pulling all of the plugs i didnt know any of that im kinda learning as i go so any info helps alot thanks mike
Countryboy1973
Sep 23, 2020 02:32 PM
Adamjmerideth
1983 - 2012 Ranger & B-Series
22
May 27, 2018 01:39 AM
djmichael24951
56
Nov 8, 2015 02:12 AM
mdsnjames
Jul 22, 2015 09:15 PM
Wiley
Jul 29, 2003 06:51 AM
