Weiand Water Pump?
Old Dec 17, 2004 | 05:18 AM
Twins's Avatar
Twins
Weiand Water Pump?
Morning folks!! Hey I have seen these Weiand pumps listed on eBay are they junk? will they bolt up proper on a 351M?...does it change the location of the thermostat and upper radiator hose routing?
Also while I am here, I need a new rear-sump pan, is there any interchange-compatability between the 351W, 351C, etc?
As always thank you
G Harrison
Old Dec 17, 2004 | 07:26 AM
danlee's Avatar
danlee
I have had a Weiand aluminum water pump for several years. They are well built. I have never had any problem. It is a direct replacement for a stock water pump.
You cannot use an oil pan from a 351W. I don't believe that the 351C ever had a rear sump oil pan. The rear sump oil pans were used on 4x4's. That limits them to 351M and 400 motors.
Old Dec 17, 2004 | 09:08 AM
mark a.'s Avatar
mark a.
You can use a 351m-400 rear sump pan on a 351c.
Old Dec 17, 2004 | 09:17 AM
danlee's Avatar
danlee
Yes, you can use a rear sump pan on a 351C. The only source is a 4x4 with a 351M or 400 motor.
