Sponsored by: Innova
Amp is Acting Weird
Old Dec 26, 2004 | 08:14 PM
  #31
MemOrex's Avatar
MemOrex
Ok I see. Don't run the ground cable all the way to the battery..keep it short. Just clean up some of that rust and ground it there or find another clean bolt around.
Old Dec 27, 2004 | 07:46 AM
  #32
LinearPower's Avatar
LinearPower
Originally Posted by Boss50
Yes, I meant I unplugged one sub. The box is homemade and seeled, but I'm thinking about putting a port hole in the top but not sure. There is a operation/protection light thats red and stays on all the time, and blinks when somethings wrong. The low voltage light is orange. I also have it grounded to the cab floor which probably isn't grounded that well considering its mounted in rubber and rust. I'm going to run a wire to the ground on the battery to take care of that.
You can't just arbitrarily cut a port in a box. Ported boxes have to be built to precise specifications. If not, you can affect the performance of the sub to the point that it won't sound like you even have a sub, and/or you can cause the sub to fail completely.
XolieX
2004 - 2008 F150
Mar 1, 2008 05:29 AM
slash31938
50
Sep 2, 2005 11:17 PM
Peach
18
Aug 23, 2005 10:27 PM
1996F150kid
28
May 11, 2004 12:11 AM
eightysix
Mar 23, 2002 12:12 PM
