Sponsored by: Innova
xm - roady2
Old Dec 26, 2004 | 04:40 PM
msu_fan's Avatar
msu_fan
xm - roady2
I received the roady2 for christmas and would like to hardwire it in. I don't wont to have to use the cig. adapter. Does anyone have any suggestions on the best way to power this thing. It has a 6volt power supply.
04 f150
Old Dec 26, 2004 | 04:53 PM
knife141's Avatar
knife141
I am installing mine tomorrow -- just went out to the truck and tested it to make sure it works before I wire the power and antenna.
I used a fuse tap and wired a power adapter with two outlets. It's the kind made for plugging into a lighter, but I removed the plug and wired it directly to the fuse box on a circuit that's only powered when the ignition is on. I've done this numerous times, and it makes for a clean installation. The 2nd outlet on my hookup goes to a radar detector. I tied the adapter up under the dash so it's out of sight.
I'm losing daylight, so I'll wait until tomorrow to finish the job. I'm going to try to run the antenna through the 3rd brake light mounting and route it under the edge of the headliner until I reach the door post, then down and under the door molding. Looks like they give you a ton of wire for the antenna.
I just spent 30 minutes sitting in my truck listening to xm. I'm glad I won't have to listen to the disc jockey babble any more!
Old Dec 26, 2004 | 05:39 PM
msu_fan's Avatar
msu_fan
Where did you mount the reciever at?
Old Dec 27, 2004 | 10:52 AM
knife141's Avatar
knife141
I mounted it in a cup holder I don't use. I used an adjustable mount from an old CD player mounting bracket. It lifted the unit to about 2 inches above the height of the cupholder.
I drive a 2003 Ranger, and the cup holders are a bit too far forward in the cab, so I installed a pair of adjustable cupholders just forward of the seat. The rear (original) cupholders are not very useful as cupholders, but one of them made a good place to mount the receiver.
I just finished installing everything a few minutes ago. Don't know if it's the same on a 150, but running the antenna wire behind the 3rd brake light was a breeze. I filed a little slot in the rubber gasket so the wire could run through, then used some sealer.
