ok here i go again. i removed my alternator and i dont know some of the hook ups are. bat is battery gnd is ground sta is unknown, and fld is unknown. i have a ground wire hooked up bat wire hooked up the other two are a condenser thing with a wire on it .where does that go? i dont have a repair manuel to it i can not find one anywhere. it is a 352 engine and a 67 f250
Ok.I extreamly tired right now so forgive me if I'm wrong but you should have one going to the battery, one going to a ground.You should also have one going to the voltage regulator and the wire with the condenser should be run near where the voltage regulator mounts to the inner fender and if I am thinking straight one connecting to a wire harness for dash gauges.I know there is a little more to it than that but it's 5:15 am and I just got in from work and dead tired.I will get my book out today and see what I can find for you.Good luck!
ok thanks i have the battery hooked up and the ground too the one with the condenser is hooked to fld. the condenser has a wire i think is a ground wire . now this is where things get wierd . i reclamped or redone all the wires they were hokiepoked together. now my alt gauve peggs to dead and does not stay in the middle like before. that is where i am confused.
The FLD wire goes to the FLD terminal on the regulator. If you send me your email address to mlh#azdeq.gov (replace the # with the at sign) I will send you back the wiring diagram. It is real simple but without a schematic you are up the creek.
Becarefull not to cause a short by hooking up the wrong wire to a ground which can burn out the alt. or the regulater. Then when it is hooked up properly it still won`t work.
ok thanks i hooked up the fld to the sta and i think i done something wrong since i did that i see my alt gauge pegg out to the d whin i turn the key. but when the key is off it is in the middle. is there a short or did i burn out a battery or alt? thanks for the help.
