Best Performance Mod?
Old Dec 14, 2004 | 08:57 PM
RR4E's Avatar
RR4E
Long tube headers are fine for running in the upper rpm band....not something you'll likely see with a 4x4. Short tube headers, will give you more everyday driving power in a useable rpm band. One thing to keep in mind....every vehical has to start from a dead stop, and accelerate. Low end and mid-range are where they spend 99% of their lives, so doing mods to improve those rpm bands will be of the most significance to you. If a mild cam is possible, great, adding short tubed, or stepped headers, with a single 3 inch exhaust will be your best bang for the buck, and add mileage, as well as more power.
Old Dec 14, 2004 | 09:22 PM
mustange70's Avatar
mustange70
To keep you O2 sensor with a dual exhaust system, just have an x, or h pipe as close as you can to the motor and have the shop weld a bung in there, then extaned the wiring for the sensor.
For what to do with the cam and efi, check out what some of the mustang guys are doing, quite a few guys are pumping some serious power out of them efi mills (but i think those guys are running maf though, but if you are up to it find a wrecked stang/lincoln/t-bird with maf and convert everything over).
Old Dec 14, 2004 | 10:09 PM
RR4E's Avatar
RR4E
As was pointed out to me earlier today, some trucks only run one O2 sensor on the right exhaust manifold, and thus true dual exhaust is fine. I find better low end and mid range from a single 3 inch for everyday driving, and prefer it's lower rumble, without the obnoxious rap that duallies give off. Your neighbors will thank you.
choate
Jun 19, 2014 12:48 PM
RaptOut
Exhaust Systems
May 10, 2010 08:17 PM
cletus_the_red
Exhaust Systems
May 1, 2008 07:12 PM
Dustin1690
75
Dec 26, 2006 10:15 PM
