Adding Weigth During Winter
Old Jan 7, 2005 | 12:13 AM
Jim Brock's Avatar
Jim Brock
I get 4 bags of 80lb salt for the water softner and place them just in front of the axle
Take them out after the season and put the salt in the water softner.
Haven't had a problem and now going into my second winter.
Old Jan 9, 2005 | 11:15 AM
Benoit1967's Avatar
Benoit1967
I personally added 4 - 55 pounds bags of sand. It changes the behavior, does not spin as easy and does not sag the back end too much.
In my opinion, 200 pounds or so is the way to go. I placed the weight behind the wheels.
Ben
Old Jan 9, 2005 | 07:24 PM
Col. Gilliam's Avatar
Col. Gilliam
Howdy,
I just had a 60+ mile trip yesterday, snow or slush covered road the entire time. Alot of steep mountain, winding roads, up hill and down hill.
4-wheel drive was all I needed. The truck is an super cab FX4 w/ 5.5' bed and a ARE LSII cover.
The key to winter driving is not to get in too big of a hurry. Having a 4X4 does not mean you can drive 70 miles an hour on an icy, slick road. Slow down.
No truck/car handles as good on ice as it does on dry pavement. Adjust your driving habbits accordingly.
Old Jan 9, 2005 | 09:24 PM
Curveman's Avatar
Curveman
No. It's a trade off. Much harder to stop/spin with the extrra weight in the back. 4X4, go slow. LSD same thing. Sucks if you are going to drive in winter. A gimmick in less you got a 2X2 then I guess it's a poor man's 4X4.
Old Jan 10, 2005 | 10:28 AM
khendrix's Avatar
khendrix
Just shovel snow into the bed of your truck.... Its free and it melts away at the same speed as the roads... Unless you park in a garage.. then I would recommend sand/salt bags in the back. I dont care what anyone else says... if you have a 2wd truck... added weight in the back is a night and day difference.
It snowed 23" here just before christmas... I loaded the bed of my 2wd truck with snow... Lots of snow.... and I had ZERO problems with traction. I was pulling people out of ditches with no slipping... Added weight=better traction... But... it also makes it harded to stop... so drive slow.
Old Jan 10, 2005 | 11:10 AM
TRITON-ic's Avatar
TRITON-ic
I put my inlaws in the back. Great traction, no chatter.
Old Jan 10, 2005 | 12:07 PM
bimmerbill's Avatar
bimmerbill
My 2004 Lariat 4x4 is great in snow. We have had some nice snow storms and some really bad ice storms in NH so far this season. The truck has done very well, with no weight added in the back.
I do try to keep the fuel tank filled tho!
Old Jan 10, 2005 | 05:15 PM
Raining111's Avatar
Raining111
I have 2004 XL 2wd, and live in Massachusetts. This being the first winter with my truck I went with the overkill method and put 320#s of gravel in the back, and it definitely helps. in fact I think 320 was perfect. What also helps in taking advantage of all the gears of the auto transmission. I've use gear 2 on the road before during the really bad storms. Gear 1 I usually only use on my drvieway as I go too slow for road use.
Old Feb 13, 2005 | 08:01 PM
Mark8too's Avatar
Mark8too
It's the wife's truck. '04 XLT 2x4 5.4. 400# water softener salt. 300# ARE cap. She never complains and goes around 4x4's that are stuck!
Old Feb 13, 2005 | 08:40 PM
truebluefx's Avatar
truebluefx
Your truck weighs thousands of pounds, just put it in 4x4 low and cruise through anything.... well almost anything.
Old Feb 13, 2005 | 08:58 PM
Mark8too's Avatar
Mark8too
It's two wheel drive and still goes through "anything".
Old Feb 14, 2005 | 12:48 PM
RyanSta80's Avatar
RyanSta80
I've never added weight to my 04 supercab 4x4, although I should. I've never had any problems with mine in 4wd, but correctly any truck on the street in the snow should have some weight in it, 2wd or 4wd. Just don't do what some guys do and over load it.The truck should sit level (if you have a leveling kit I guess your out of luck, LOL). If you load too much then you lose the abilty to steer, which of course makes the problem even worse.
Old Feb 14, 2005 | 01:20 PM
  #28
lardman's Avatar
lardman
I go to Home Depot and buy an 80# bag of cement, put it in a commercial grade garbage bag (so it doesn't get wet), and set it over the right rear tire. I have a 2x6 in the slots of my bed liner so I screwed 2 2x4's to make a partition big enough to keep the bag from sliding around. When spring comes, return the bag of cement so it isn't laying around the garage When I had my old s-10 I used to fill the back with snow...didn't help keep it from rusting though
Jerky's_06 F350
All Things Towing
21
Dec 18, 2016 12:00 PM
Patrick R.
General Automotive Discussion
Dec 6, 2016 05:33 PM
clark grizwald
Nov 16, 2016 02:35 PM
audimotion
6.7L Power Stroke Diesel
Dec 6, 2011 01:07 PM
pud
17
Aug 14, 2006 08:51 PM
