changing timing chain on a 351m
Old Dec 11, 2004 | 11:57 PM
maddog72's Avatar
maddog72
can anyone tell me if i have to take off the oil pan to change the timing chain on a 351m 1979 f250?????
Old Dec 12, 2004 | 12:09 AM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Welcome to FTE maddog.
Thanks for joining us!
Old Dec 12, 2004 | 12:13 AM
Mil1ion's Avatar
Mil1ion
Yes, at least the front 4 bolts & loosen the others
Old Dec 12, 2004 | 05:13 PM
maddog72's Avatar
maddog72
so do i have to raise the engine like if i was changing the oil pan gasket?
Old Dec 13, 2004 | 01:37 PM
grclark351's Avatar
grclark351
i have never loosened or removed any pan bolts. i trim a little off the ends of the inside tabs that hold the pan end seal so that the cover can sneak back in. not too much, just the little corners. and i reuse the old end seal(if it's ok) because it is smooshed a little and goes in easy. test fit the cover before you put the seal on to see if it sneaks in ok. use a little rtv on the inside where you trimmed and on the end seal. i haven't had one leak yet...by the book you should drop the pan and reseal it too.
TheSterling
Apr 19, 2016 09:05 AM
zemus420
Sep 15, 2015 02:42 PM
derbydad276
May 25, 2015 06:05 AM
erik68
Feb 8, 2015 06:47 PM
abyars111
Jul 17, 2013 08:33 PM
